Is A a Measurable Set with Sandwich Property?
  • Thread starter Thread starter Funky1981
    Measurable Set
Funky1981
Suppose that A is subset of R (real line) with the property for every ε > 0 there are measurable sets B and C s.t. B⊂A⊂C and m(C\B)<ε
Prove A is measurable
By definition A is measurable we need to prove m(E)=m(E∩A)+m(E\A) for all E
the ≤ is trivial enough to show ≥:
Since C is measurable then m(E)= m(E∩C)+m(E\C)
≥ m(E∩A)+m(E\A)-ε (Since A is subset of C)
then move the ε to LHS and since for every ε so, let ε->0 , obtain the result.
is my solution right? i thought i should use B and m(C\B)<ε somewhere. Could some one help me to check it??
many thanks
I assume your ##m## denotes outer measure. I'm not sure how you obtained your inequality
$$m(E \cap C) + m(E\setminus C) \geq m(E \cap A) + m(E \setminus A) - \epsilon$$
I agree that ##m(E \cap C) \geq m(E \cap A)##, but how did you get the rest?
I was able to solve this pretty straightforwardly by using the fact that ##B## and ##C## are measureable.
Given ##\epsilon > 0##, there are ##B## and ##C## such that ##B \subset A \subset C## and ##m(C \setminus B) < \epsilon##. Let ##E## be any set. Since ##B## and ##C## are measurable, we have (*)
$$m(E) = m(E \cap C) + m(E \setminus C)$$
and
$$m(E) = m(E \cap B) + m(E \setminus B)$$
We also have the following inequalities due to the nesting of the sets:
$$m(E \cap B) \leq m(E \cap A) \leq m(E \cap C)$$
$$m(E \setminus C) \leq m(E \setminus A) \leq m(E \setminus B)$$
Adding these two inequalities, we get
$$m(E \cap B) + m(E \setminus C) \leq m(E \cap A) + m(E \setminus A) \leq m(E \cap C) + m(E \setminus B)$$
In light of (*) above, it therefore suffices to show that ##m(E \setminus B) \leq m(E \setminus C) + \epsilon##. But this follows easily from the fact that ##E \setminus B = (E \setminus C) \cup (E \cap (C \setminus B))##.
One nice consequence of this exercise is that we can immediately see that a measure obtained from an outer measure is complete: in other words, any subset of a set of measure zero is measurable. To see this, simply take ##B = \emptyset## and let ##C## be any set of measure zero.
Another way to do this:
For any n\in\mathbb{N} \exists B_n, C_n s.t. B_n \subset A \subset C_n and m(C_n \setminus B_n)&lt;1/n
Then m(A \setminus \bigcup _{i=1}^∞B_n)≤m(C_n \setminus B_n)&lt;1/n for all n \Rightarrow m(A \setminus \bigcup _{i=1}^∞B_n)=0 \Rightarrow A \setminus \bigcup _{i=1}^∞B_n is measurable \Rightarrow A = (A \setminus \bigcup _{i=1}^∞B_n) \bigcup (\bigcup _{i=1}^∞B_n) is measurable, since each B_n is measurable and the measurable sets form a σ-algebra.
That's a nice proof. It requires knowing that any set with zero outer measure is measurable, but that's easy enough to prove directly from the Caratheodory criterion:
If ##E## is any set and ##m(A) = 0##, then ##m(E \cap A) \leq m(A) = 0##, so ##m(E \cap A) + m(E \setminus A) = m(E \setminus A) \leq m(E)##. The reverse inequality, ##m(E) \leq m(E \cap A) + m(E \setminus A)##, is an immediate consequence of subadditivity.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
