Satellite Beam Weights Explained | Learn What They Are
In summary, satellite beam weights, specifically phase and amplitude weights, refer to the programming of elements in a phased array antenna to create desired antenna power patterns for beam forming. This technology is commonly used in smart antennas for cellular phone base stations and WiFi MIMO systems. Additional information can be found in references such as Skolniks Radar Handbook and specific texts on smart antennas.
CatWoman
30
Hi, can anyone explain satellite beam weights, I think more precisely, phase weights and amplitude weights. I am starting a job next week and at my interview they mentioned these. I am trying to read up on these before I start and can't find anything useful on the internet.
Many thanks.
Many thanks.
I'm not an expert in this specifically but I used to work with satellites. It's about "smart antennas" based on "phased array" techniques for "beam forming". The weighting is referring to the "programming" of phased array elements' amplitude and phase.
Essentially you can get arbitrary antenna power patterns, e.g. beaming in a signal from geosync orbit and creating a beam pattern that covers only a specific territory of commercial interest. For example, say you wanted to beam satellite TV to Malaysia but not Thailand or Indonesia (see at a map of SE Asia). You could create a specific beam pattern to do that.
Useful background references: Skolniks Radar Handbook (borrow it first from an engineering library - it's pricey) which has a nice section on microwave phased array antenna. There are probably specific texts available on smart antenna or adaptive antenna systems. These are used quite extensively now for cellular phone base stations. Wifi MIMO is pretty much the same concept but with an array of 2 antennae.
Thanks - given those keywords I was able to find out enough on the internet for now - many thanks!
1. What are satellite beam weights?
Satellite beam weights refer to the distribution of power across different areas of a satellite's coverage zone. This is important because it affects the strength and quality of the signal received by users on the ground.
2. How are satellite beam weights determined?
Satellite beam weights are determined by the satellite operator based on factors such as the satellite's power, antenna size, and frequency bands used. They are also influenced by the location and needs of the satellite's target market.
3. What is the purpose of satellite beam weights?
The purpose of satellite beam weights is to optimize the satellite's coverage and provide the best possible signal strength to users in different areas. This allows for efficient use of the satellite's resources and ensures reliable communication services for users.
4. How do satellite beam weights affect satellite communication?
Satellite beam weights play a crucial role in satellite communication as they determine the strength and quality of the signal received by users. The weights also impact the satellite's bandwidth and capacity, which can affect the speed and reliability of data transmission.
5. Can satellite beam weights be adjusted or changed?
Yes, satellite beam weights can be adjusted or changed by the satellite operator. This is often done to optimize coverage or accommodate changes in demand for satellite services. However, it can be a complex and costly process, so changes are usually carefully planned and implemented.
  • General Engineering
  • Aerospace Engineering
