How do I determine the minus sign in gauge transformations?
The discussion centers on determining the correct sign in gauge transformations for electromagnetic potentials. It starts with the definitions of the magnetic field \(\vec{B}\) and electric field \(\vec{E}\) in terms of the vector potential \(\vec{A}\) and scalar potential \(\varphi\). The speaker explores how changing the definitions of \(\varphi\) and \(\vec{A}\) affects the resulting fields, emphasizing that the sign is crucial for maintaining consistency in the equations. The transformation of potentials is clarified through the relationship between contravariant and covariant four vectors, where the raising of indices introduces the necessary minus sign. Understanding these transformations is essential for correctly applying gauge invariance in electromagnetic theory.
Petar Mali
\vec{B}=rot\vec{A}
\vec{E}=-\frac{\partial\vec{A}}{\partial t}-grad\varphi
If I define
\varphi=\widetilde{\varphi}-\frac{\partial f}{\partial t}
\vec{A}=\widetilde{\vec{A}}+gradf
where
f=f(x,y,z,t)
I will get
\vec{B}=rot\vec{A}=rot\vec{\widetilde{\vec{A}}}
\vec{E}=-\frac{\partial\vec{A}}{\partial t}-grad\varphi=-\frac{\partial\widetilde{\vec{A}}}{\partial t}-grad\widetilde{\varphi}
But if I say
\varphi=\widetilde{\varphi}+\frac{\partial f}{\partial t}
I wouldn't get that result. How I know how to take minus sign in this relations!
The transformation for A is clear, because you want B to stay the same and you simply exploit the fact that grad(rot F) = 0 for any vector field F.
So then you can simply define \tilde\phi = \phi + \delta, write out
-\frac{\partial \tilde{\vec A}}{\partial t} - \nabla \tilde\phi
and see what \delta has to be to cancel the extra term from the \tilde A-derivative so you get
-\frac{\partial \vec A}{\partial t} - \nabla \phi
back.
Another way to see it is with four vectors:
Define the (contravariant) four potential putting together the scalar and vector potential:
A^\mu=(\phi,\mathbf{A})
and define the (covariant) four derivative putting together the time derivative and the gradient:
\partial_{\mu}=(\partial_t,\nabla)
Then the gauge transformation is simply
A^\mu\longmapsto A^\mu+\partial^\mu f
and the fact that you have to raise the index of \partial_\mu yields the minus sign.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
