What is the Scale of Homogeneity in the Universe and How is it Measured?
  • Thread starter Thread starter skippy1729
    Homogeneity Scale
The universe is considered homogeneous at scales larger than approximately 300 million light-years, where galaxy number counts become nearly constant despite existing inhomogeneities. Measurements often involve analyzing large fields of galaxies and counting their distribution in various sized boxes. However, smaller scales can still show significant voids and filaments, complicating the understanding of homogeneity. The scale of homogeneity also evolves with the universe's age, as earlier epochs exhibited more uniform mass distributions. For further insights, statistical studies from galaxy catalogs and definitions of homogeneity are recommended.
skippy1729
Above what scale is the universe considered to be homogeneous? What sort of measure is used? I've looked at a few cosmology texts and they don't really discuss it much. Weinberg states 300 million LY. With 250 million LY diameter voids and 1370 million LY long filaments, 300 million LY seems like a very lumpy soup! Any references would be appreciated.
Skippy
Space news on Phys.org
Skippy
Well, there are inhomogeneities on all scales, but most of them are filtered out at scales larger than around 300 Mly or so. One rather direct way to measure this is just to take a large field of the sky with lots of galaxies, and start doing number counts of galaxies in each box at different size scales. Once you hit around 300Mly or so, those number counts become very nearly constant. Not actually constant, of course, but nearly so.
I assume that you are talking about some sort of 3D box sorted by redshift distance. But unless the box dimensions are much larger than 300 Mly some will be dominated by voids and some by walls and filaments. If you are talking about dividing the sky into a 2D grid, uniformity will only imply isotropy which will not imply homogeneity without additional assumptions.
Do you have any references to actual calculations?
Skippy
Skippy
Hmmm, sadly it was too long ago, and I'm unable to find the original reference. You may be right, it might have been an examination of isotropy and not homogeneity.
Actually, it also works in 3D. The scales you quote for voids and filaments are very rare exceptions, most are much smaller. Indeed, if you smooth the 3D density field on scales of ~300 MLyr you will find roughly the same total mass in all these volumes. The errors on that follow Poisson statistics, exactly what you expect for the shot noise in purely random fields.
The scale at which this homogeneity appears depends on the age of the universe. In the very early universe the mass distribution was already more homogeneous at much smaller scales. Larger scale fluctuations in the density field start to evolve non-linearly later. Google some of the terms here, and include terms like sigma-8 and collapse and you will find more info! Good luck!
Thanks, I will look into this. So far, everything I have come across regarding homogeneity is indirect evidence that is probably model dependent. I am really looking for a statistical study from star/galaxy catalogs and also an explicit definition homogeneity.
Skippy
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
