Understanding BJTs: A Beginner's Guide
  • Thread starter frixis
In summary, the conversation revolves around the topic of understanding BJTs (bipolar junction transistors). The individual is having trouble grasping the concept but is seeking resources, such as books and websites, to help explain it in simpler terms. The conversation also includes a suggestion to experiment with a physical BJT component and a humorous analogy to understand its functioning. The individual expresses gratitude for the help and plans to continue studying the topic.
frixis
okay for some strange reason I'm very very scared of bjts .. i don't know maybe i just don't get em at alll... is there some site or some book that explains bjts in the simplest terms??
u know something crude that gives u the basics??
What don't you understand about them? Basically they are just switches. Similar to light switches at home except that bjts can switch on and off millions of time per second.
http://www.uoguelph.ca/~antoon/tutorial/xtor/xtor.html
The above might help.
Claude
There are some good lecture videos/animations on youtube.
i don't know I'm just scared of them.. i read the book and it goes over my head .. OVER my head.. using sedra smith and a systems approach to electronics... its just confusing... and i spend half the time trying to figure out what's happening to the electrons ...
Start here if you are reading from books-
Art of electronics and Electronic devices by David A.Bell
Basically its like a vacuum tube. You make electrons in one terminal, you collect them in the other. You insert a 'gate' halfway to control the amount of electrons.
Do you mean bjts (bipolar junction transistors), like npn and pnp? Get a 2N3055 and 2 one-watt, 100 ohm resistors. Connect the collector to + 15 volts thru one 100 ohm resistor. Connect the emitter to ground through the other resistor. Get a 1k pot, connect it between ground and + 10 volts, and the wiper to the base through a 1k resistor. Now monitor the collector and emitter voltages and vary the base voltage. Plot the emitter and collector voltages as a function of the base voltage.
I like John Popelish's "drunken bum on a crazy street transistor analogy".
See the second post here:
http://groups.google.com/group/sci....ead/thread/33b0250add6a6c89?tvc=2&q=jpopelish
Oh heck, I'll just go ahead and repost it:
John Popelish said:
andrew_h wrote:
> I am new to electronics - I have learned heaps and am enjoying every new
> thing I'm learning.
(blah blah blah)
> Something that has been confusing me no-end, and I just can't seem to
> grasp, is how a TRANSISTOR works!
> I have read many explanations, but they are confusing and vauge.
(blah blah blah)
> Any help with this would be greatly appreciated ... this is really
> proving to be a stumbling block ...
Here is the not exactly right approximate run through.
There are two PN junctions in a transistor, one is the emitter to base
junction and one is the base to collector junction. Normally, the
base to collector junction is reverse biased, to produce an insulating
layer between the base and collector with no movable charges.
Lets pick a polarity... NPN.
So the collector has a positive voltage with respect to the base, so
the doped in electrons in the collector N material are attracted away
from the base and the holes in the base are attracted away from the
collector, leaving just insulating silicon between them.
When the base emitter junction is slightly forward biased (emitter
relatively more negative and base relative more positive), the doped
in electrons in the emitter are repelled toward the base, and the
holes doped into the base are repelled toward the emitter. At about a
half volt forward bias, the holes and electrons begin to find each
other and the electrons tend to jump into the holes and both
effectively dissappear. However, a well made transistor has the
emitter much more highly doped than the base, so more electrons get
pushed into the base than holes get pushed into the emitter.
So the holes that get pushed into the emitter are annihilated very
quickly, but the electrons that get pushed into the base have to hunt
around a while beforo they dissappear.
The small positive base voltage causes these electrons to wander
toward the base lead (the most positive voltage around them). But the
base layer is very thin, and the electrons drift rather slowly in that
direction. If the temperature was very low, this is about all that
would happen, and the forward biased base emitter junction would have
almost no effect on the collector curret.
But at normal ambient temperatures (well above absolute zero) the
movement of the electrons is randomized by the thermal energy in the
silicon, so they stagger quite randomly, with only a little progress
toward the base lead. And since the base layer is so thin, most of
them will never make it to the base lead. They will fall off the
cliff into the highly stressed charge-empty reverse biased base
collactor junction. There, instead of wandering in a drunken stagger
through a very small electric field (volts per meter) they will whoosh
out of the reverse biased junction, because it is much more highy
stressed with e-field. They become collector current.
The more strongly you forward bias the base emitter junction, the more
electrons are pushed into the base layer, and the more stagger over
the cliff into the collector, though there will also be more that make
it out the base lead. Over a wide range of collector current, the
collector be a fairly fixed multiple of the base current. This is the
transistor's current gain or beta.
So the electrons are drunks being encouraged with a slightly tilted
sidewalk onto a slightly down hill, vibrating curb, next to street
that tilts away from the curb, very steeply. Most never make it to
the end of the curb, but fall onto the street where they slide into
traffic.
This is the drunken bum on a crazy street transistor analogy.
thanks... reading the bum on a drunken street analogy calmed me down a bit.. enuff to be able to go and hit the books again... i hope i get something this time... :D
if i don't its back to this thread ...
:D :D
thankyou everyone..
and i'll try getting a pair of bjts and experiment with them soon enuff (Godwilling)
Related to Understanding BJTs: A Beginner's Guide
What is a BJT?
A BJT or bipolar junction transistor is a type of semiconductor device that is used as an electronic switch or amplifier. It is composed of three layers of different types of materials, namely the emitter, base, and collector.
How does a BJT work?
A BJT works by controlling the flow of current between its emitter and collector terminals using a small current at the base terminal. When a small current is applied to the base, it creates a larger current flow between the emitter and collector, thus amplifying the signal.
What are the different types of BJTs?
There are two main types of BJTs - NPN and PNP. NPN BJTs have a thin layer of P-type material sandwiched between two layers of N-type material, while PNP BJTs have a thin layer of N-type material sandwiched between two layers of P-type material.
What are the key characteristics of a BJT?
The key characteristics of a BJT include its current gain, voltage gain, and frequency response. Current gain is the ratio of output current to input current, while voltage gain is the ratio of output voltage to input voltage. The frequency response refers to the range of frequencies that the BJT can handle.
What are some common applications of BJTs?
BJTs are commonly used in electronic circuits as switches and amplifiers. They are also used in audio equipment, power supplies, and communication devices. They are essential components in many electronic devices and play a crucial role in modern technology.
  • Electrical Engineering
16K
  • Feedback and Announcements
  • STEM Academic Advising
  • Science and Math Textbooks
