Schwarzschild Metric with multiple masses
DiamondGeezer
I know that it's possible to calculate the rate at which time flows when in the gravitational field of a single spherical mass.
But how do you calculate the rate when there are two masses or more? How do they add together?
In order to calculate this, you need to know the metric that is the solution to Einstein's equation for this particular physical situation.
Regards,
George
Since Einstein's Equations are nonlinear PDEs, one may not be able to superpose solutions exactly. Some approximate model will probably have to be used.
Exact solutions are very difficult. The PPN approximation, which is valid only in weak fields/low velocities gives the metric coefficient g_00 = 1-2U (in geometric units), where U is the Newtonian potential energy. This means that the time dilation factor is sqrt(1-2U), which is equal to 1-U in the region where the approximation is valid (U << 1).
Note that gravity in the solar system can be considered to be "weak field".
By "time dilation factor" I mean a number less than 1, i.e. a time dilation factor of .5 means that a clock at that location run half - fast (though such a large time dilation factor would be outside the region where the PPN approximation worked well).
U is the [correction] negative of the Newtonian potential energy / unit mass (U is always positive, the energy is always negative) which is dimensionless when c=1 (i.e when one is using geometric units). U must be zero at infinity.
So roughly speaking, if one is at a distance r1 from mass m1 and a distance r2 from mass m2 in a weak field
U = m1/r1 + m2/r2 (in geometric units). (Note the sign correction).
In non geometric units, one would write the time dilation factor (defined in the same way) as
1 - G*m1/(r1*c^2) - G*m2/(r2*c^2)
Thank you for your answers. That helps a lot.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
