What Happens If You Jump Into a Hole Drilled Through the Earth?
  • Thread starter Thread starter Cowkilla
    Science
If a person jumps into a hypothetical tunnel drilled through the Earth, they would initially accelerate due to gravity until reaching the center, where they would have maximum speed. Without friction or other limiting factors, they would then continue to oscillate back and forth between the North and South Poles, demonstrating damped simple harmonic motion. Over time, air resistance would gradually slow their motion until they eventually come to a stop at the center. The scenario assumes ideal conditions, ignoring real-world factors like extreme heat and tunnel collapse. Ultimately, the jumper would not simply pass through but would oscillate indefinitely until friction brings them to a halt.
Cowkilla
Science question: need some help!
I have a question that's been bugging me for ages:
If someone were to drill a hole through the Earth and jump into it. Let say the tunnel spans from the North to South, and we ignore the limiting factors, such as the extreme heat and the hole won't collapse and there is sufficient oxygen, what will happen?
I remember reading it from the Popular Science magazine (June 2005) and I really need to know what will happen, because I forgot the answer and why! Will the guy just pass through the tunnel and end up on the other side, or will he go through the tunnel and stop at the center of the Earth as a result of gravity? :confused:
Without friction or other "limiting factors" the jumper will have acquired rather significant momentum by the time he reaches the center of the Earth and will simply keep on going.
He will display damped simple harmonic motion. He will oscillate between the north pole and south pole, gradually slowing down due to air friction and so on.
- Warren
Unless someone is waiting at the south pole to catch him, of course...
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
