Scientists cover the mirror with a stratum that doesn't hold water
  • Thread starter Thread starter sitokinin
    Mirror Water
Scientists have developed a method to coat mirrors with a stratum that prevents water from adhering, allowing for a clear reflection after showering. This involves applying a thin layer of oil followed by detergent, where the detergent's hydrophilic and hydrophobic ends interact to reduce water droplet surface tension. The resulting effect causes water to bead up instead of creating a foggy layer. The thickness of these coatings is crucial, ideally less than 0.5 microns, to maintain optical clarity. Understanding the atomic arrangement of these layers is essential for further exploration of this technology.
sitokinin
I'm a high school student.
I heard that scientists cover the mirror with a stratum that doesn't hold water. Thus when you get out of the shower, you can see your reflection into the mirror in a smooth way.
I've been searching this structure. I want to indicate my ideas with composing them. How does the atoms in this system line? Could you suggest me a website or a direct person to find what the system's strucure is?
Science news on Phys.org
As far as I know (which is very little) the idea is simply to first aplly a thin coat of an oil followed by a similar coat of some detergent. The detergent molecules have hydrophilic and hydrophobic ends. The hydrophobic ends bond well with the oil layer, making the hydrrophilic ends stick out. When a water droplet forms on the mirror, the hydrophilic ends stick to the surface of the droplet reducing its surface tension. This causes the water to bead up, rather than form a fine foggy dispersion or layer.
It's not much different from a car wax, I imagine. The only significant difference is that you might want the thickness of the layers to be not much larger than the wavelength of light (less than 0.5 microns thick).
Hmm... I wonder that do the scientists line these atoms just top of the mirrors surface or they line them with an orderly regulation?
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
