Second order differential equation.(Damped oscillation)
3 replies · 3K views
mr pizzle
Hi could do with a little help with this question please!
The question
A damped oscillation with no external forces can be modeled by the equation:
[itex]\frac{d^2x}{dt^2}[/itex]+2[itex]\frac{dx}{dt}[/itex]+2x=0
Where x mm is amplitude of the oscillation at time seconds. The initial amplitude of the oscillation is 3mm (i.e. when t=0) and the intial velocity is 5mm/s.
Solve the equation for x.
Ok! so far I have;
[itex]m^2+2m+2=0[/itex]
[itex]\frac{-b±\sqrt{b^2-4ac}}{2a}[/itex]
[itex]\frac{-2±\sqrt{2^2-4x1x2}}{2x1}[/itex]
[itex]\frac{-2±\sqrt{-4}}{2}[/itex]
[itex]\frac{-2}{2}[/itex]±[itex]\frac{\sqrt{-4}}{2}[/itex]
m=-1±j[itex]\frac{\sqrt{4}}{2}[/itex]
Equating this with m=α±jβ
Gives α=-1 β=1
Substituting into the general solution (complex roots)
x=e-1t[Acos(t)+Bsin(t)]
x=3 t=0
3=e-1x0[Acos(0)+Bsin(0)]
3=A
This is the part we are unsure of!
[itex]\frac{dx}{dt}[/itex]=e-1t[-Asin(t)+Bcos(t)]-1e-1t[Acos(t)+Bsin(t)]
By the product rule;
=e-1t[B-A]cos(t)-[A-B]sin(t)
x=0 [itex]\frac{dx}{dt}[/itex]=5
5=e0[B-A]cos(0)-[A-B]sin(0)
5=[B-A]
We know A=3 so therefore B=8
x=e-1t[3cos(t)+8sin(t)]
Is this correct? If not any help would be greatly appreciated.
Just wasn't sure. Followed it from a book from a similar question and don't fully understand it! The question was different enough to have doubts!
when you have the solution, you can substitute it into your differential equation to see if you end up with 0.
