Seebeck generator from placing water heater next to freezer
The discussion centers on the feasibility of using a thermoelectric generator to harvest energy from the temperature difference between a water heater set at 130°F and a freezer at 5°F. Participants conclude that due to the laws of thermodynamics, particularly the conservation of energy, such a setup would not yield a net gain in energy. Insulation of both appliances further diminishes any potential energy capture, making it impractical. Instead, suggestions include using a heat exchanger or a heat recovery chiller to improve efficiency in heating water while cooling refrigerant.
  • Understanding of thermoelectric generators and their efficiency
  • Knowledge of the laws of thermodynamics, particularly conservation of energy
  • Familiarity with heat exchangers and their applications
  • Awareness of heat recovery systems and their benefits
  • Research the principles of thermoelectric generation and its efficiency metrics
  • Study the laws of thermodynamics, focusing on energy conservation and efficiency
  • Explore the design and implementation of heat exchangers in residential systems
  • Investigate heat recovery chillers and their applications in energy efficiency
Engineers, energy efficiency consultants, and homeowners interested in optimizing energy use in heating and cooling systems.
DWT
Water heater is set at 130 degree f freezer is 5 degrees f.
Is it possible for a thermoelectric generator to collect energy from these placed side by side?
Would the extra energy used by the heater and freezer due to the presence of the generator cancel out and then some any energy that could be collected?
Science news on Phys.org
If I read your question correctly, the answer is:
There cannot be a perpetuum mobile (PMM) in our universe. (Reason: laws of thermodynamics)
I am not suggesting a perpetuum mobile, i am asking more about conservation of energy. Since one thing is already hot the other cold couldn't we conserve some of that energy and give it back to grid?
Short answer is "no." A freezer pumps heat from the inside chamber and exhausts it externally in its refrigeration cycle. The outside of the freezer gets warm.
It would be better to have the watersupply going into a water heater jacket where the incoming water is cold, and put your peltier device inbetween the jacket and water tank.
The reality is, its not cost effective.
The water heater and freezer are both insulated to prevent heat transfer. That's the opposite of what an energy harvesting device needs. So there really is almost no energy available to be captured and at an extremely low delta-T (because of the insulation), you get an extremely low efficiency.
Broader; the laws of thermodynamics do indeed forbid such a device from being useful, even if it isn't obvious how. The energy required to create your temperature difference must always be greater than the energy gained by harnessing it. In this case, it is particularly bad because most electric water heaters don't even use a heat pump (COP: 4:1), they use resistors (efficiency: 100%/COP: 1:1)
It would be better to have the watersupply going into a water heater jacket where the incoming water is cold, and put your peltier device inbetween the jacket and water tank.……
Or maybe just set up a heat exchanger between the two, so that heat from the compressed refrigerant fluid gets put into the cold water entering the tank? This would perform some of the work of heating the water and cooling the refrigerant, practically for free. Wouldn’t that reduce the amount of energy needed to do both jobs? Would probably work best when the water is in motion, so I don’t know how much of a savings it would be. Just a thought.
In fact, this product already exists: it's called a heat recovery chiller. It makes process hot and cold water at the same time, instead of rejecting the condenser heat to nowhere useful.
https://www.carrier.com/commercial/en/us/products/chillers-components/heat-recovery/
Really, it's just different in function from a normal water cooled chiller.
It isn't done on a scale as small as a residential refrigerator that I know of though.
  • · Replies 35 ·
  • · Replies 152 ·
11K
12K
