Separating angular and linear momentum
The discussion revolves around the separation of angular and linear momentum in systems such as an inverted pendulum and a rod subjected to various forces. Participants explore the mechanics of these systems, particularly in relation to running techniques and the effects of gravity on motion.
  • Some participants question whether angular and linear momentum can be treated separately in the context of an inverted pendulum.
  • One participant proposes that the horizontal component of linear momentum remains unchanged just before the rod leaves the platform, raising questions about the relevance of angular momentum in calculating linear acceleration.
  • Another participant describes a scenario with a rod in space subjected to forces, suggesting that the forces create torque and angular acceleration around the center of mass.
  • There is a discussion about the ground reaction force (GRF) acting on the rod, with some participants asserting that it does not necessarily equal the weight of the rod when it is leaning.
  • Participants explore how to calculate the linear acceleration of the rod based on the forces acting on it, particularly when considering the effects of gravity and friction.
  • One participant expresses uncertainty about how to calculate the magnitude and direction of the GRF when the rod is leaning and friction prevents slipping.
  • There is a consideration of how gravity might contribute to propulsion in running, particularly when the runner is leaning forward, and whether this effect is independent of the horizontal GRF.
Participants express differing views on the relationship between angular and linear momentum, the behavior of the GRF, and the implications for running mechanics. The discussion remains unresolved with multiple competing perspectives on these topics.
Participants highlight limitations in their assumptions regarding the forces acting on the rod and the conditions under which the GRF operates. There are unresolved questions about the calculations needed to fully understand the dynamics of the systems discussed.
simbil
Is it possible to separate the angular and linear momentum and treat them separately in a system such as an inverted pendulum?
For example, a pole on a platform balancing on its end. If it is unbalanced so that it falls off the platform, it goes through motion like an inverted pendulum until it leaves the platform at which point it has angular momentum around its COM and linear momentum of its COM with vertical and horizontal components (correct me if I'm wrong here).
Is the horizontal component of linear momentum of its COM the same just before it breaks contact with the platform as it is when it is falling?
If so, does that mean that angular momentum could be ignored when calculating horizontal linear acceleration?
Finally, can anyone point me to the kind of calculations I could do to discover the linear horizontal momentum change generated in this scenario?
Maybe I didn't explain that very well, let me try again.
Taking the scenario of a non-accelerating rod in space.
2 equal and opposite forces are applied simultaneously to the rod. The first is applied at the rod's COM at an angle of 5* to the vertical. The second is applied at the rod's end at 5* to the vertical, so that both forces are directly opposite each other.
I would expect the forces to combine and create a torque that would cause angular acceleration of the rod around its COM.
Now if a third force is introduced at the end that prevents it from rotating, the rod will move like a pendulum, pivoting about its base.
Once all the forces are removed, I would like to calculate the linear acceleration that the rod has experienced.
I presume I can calculate the linear acceleration simply by considering force 3 and using F = ma?
If I can get confirmation on that, I can go on to the second part of the problem. This all relates to a problem I am trying to solve regarding the mechanics of running, the effect of gravity and correcting the angular motion so the runner does not fall on his face.
Sounds good to me. (The first two forces cancel out.) Using F = ma will give you the acceleration of the rod's center of mass.
Doc Al,
Thanks for the response. The idea of the first 2 forces is that they are acting at an angle to the rod so there is an effective lever arm between, probably wasn't clear from my description - that's what the 5* angle from the vertical for force application was for.
Presuming that is right, the second part of the question is to relate the first scenario to an inverted pendulum. So, a simple rod resting vertically on the Earth is tipped forwards so that it falls over.
The forces would be gravity acting on the COM vs vertical GRF at the base, both equal and opposite but offset from each other so they produce rotation - like the first 2 forces in the previous example. The third force is horizontal GRF provided by friction that stops the base slipping as the rod rotates and falls.
If ground contact instantaneously ceases part way through the fall, can I calculate the linear acceleration at that point from the sum of the horizontal impulses up to that point?
I think that should be OK, and if so it leads on to the 3rd and possibly final question.
Don't assume that the upward normal force exerted by the ground is equal and opposite to the gravitational force on the COM. (That's true while the rod is vertical, but not once it starts falling.)
Doc Al,
I did wonder about that as I typed it. Is it actually the case that the GRF acts along the rod with magnitude equal to the weight of the rod?
Yes. You can either think of an "infinitesmal" force acting on an infinitesmal mass at each point on the rod (so that the integral along the length of the rod is equal to its weight) or you can think of the entire weight as acting at the center of gravity of the rod.
No.
I assume that GRF stands for 'Ground Reaction Force', which is your term for the contact force that the ground exerts on the rod? If I'm misinterpreting what you mean, let me know.
Doc Al,
Yes, GRF is ground reaction force, the force exerted by the ground at the contact point with an object.
I presumed that the GRF would be equal in magnitude to the rod's weight but with its direction along the rod. When the rod is vertical, GRF and weight cancel and so there is no net external force.
When the rod is leaning over, GRF would have a vertical component that is less than the rod's weight and a non-zero horizontal component (assuming sufficient friction).
So that would create a change in momentum seen as the COM of the rod moving horizontally and downwards.
Is that right?
No. In general, that's not true.
That's true.
That's also true. But the magnitude of the GRF does not necessarily equal the weight of the rod, nor is the direction of the GRF necessarily parallel to the rod.
Doc Al,
OK, seems like I am on the wrong track then.
So if take the example of a leaning rod, how do we calculate the GRF's magnitude and direction assuming that the ground does not yield and that friction is sufficient to stop the rod slipping?
OK, as no answer is forthcoming, I guess what I asked has no simple answer.
To wrap this question up, I will go on to the main issue.
I am discussing running technique with a number of people and particularly the role of gravity in running. Gravity is neutral over an entire running cycle, but there are points when it could be helping with propulsion, namely when the runner is leaning forwards of the support point.
If gravity does net work on the runner's COM, I presume that it will create an inverted pendulum type motion which will have elements of angular and linear acceleration. For the runner to avoid falling on their face from the angular motion, they need to counter it. To counter the angular motion, the runner can push back against the ground to produce a somewhat forwards acting GRF. This force will add linear acceleration and also counter the angular motion.
The big question for me is, if angular motion is corrected instantaneously with horizontal GRF, will gravity still do linear work on the runner i.e. will the net propulsion at that point be the sum of horizontal GRF plus a component of linear acceleration from gravity? Or will the net propulsion only be from horizontal GRF? Or something else :smile:
You can calculate the GRF on the falling rod by first figuring out the acceleration of the rod's center of mass. Treat the rod as being in pure rotation about the contact point and make use of conservation of energy. (Sorry about not answering sooner.)
Thanks Doc Al, that makes sense and I can see why I cannot assume that the GRF will act along the rod.
Onto my last point as I posted above. To abstract the runner into an easier physical model, we can consider a leaning rod (not vertical or horizontal) on a trolley.
If the trolley is accelerated such that the lean of the rod does not increase or decrease, how can the linear acceleration of the system (trolley and rod) be calculated, or if it is easier in words, does the rod's COM experience linear acceleration by both gravity making it fall and the force applied to the trolley, or just by the force applied to the trolley? In essence, can it be said that gravity is doing work on the rod in this scenario?
For a leaning rod on a trolley, it would be easy to calculate the acceleration required to maintain a given angle. (Viewed from an accelerated frame, there would be a non-inertial force on the rod equal to '-ma' acting at its center of mass.)
As far as gravity doing work, realize that gravity acts vertically while the rod's displacement is horizontal. So no work is done by gravity.
Thanks Doc Al.
I appreciate that gravity acts vertically. My confusion and questions arise from the fact that when a rod falls over, it's COM is lowered and also moved horizontally so gravity is instrumental in a horizontal movement - when it acts on a leaning rod it creates a non-vertical GRF at the base through friction.
If we assume that friction stops the base of an object from slipping, is it not true to say that the instantaneous horizontal force of a leaning rod is m.g.sin(x)?
I get the impression though that gravity will not be doing any work in the accelerated trolley scenario as the rod would need to fall forwards for gravity to be adding anything, right?
How did you deduce this? (By 'instantaneous horizontal force' you mean the horizontal component of the GRF, right?)
Right.
Yes, I mean the horizontal component of GRF, excuse my wandering language :)
For the scenario of a simple leaning falling rod:
Gravity acts on the COM and it's force can be expressed as m.g acting vertically downwards.
There is a GRF acting at some angle (Θ) in the rod COM's quadrant assuming friction prevents the rod from slipping.
I'm assuming from Newton's 3rd law, we can say that GRF = mg (1)
The GRF component in the horizontal direction is GRF.sin(Θ) (2)
substituting (1) and (2) gives
the GRF in the horizontal direction = m.g.sin(Θ)
Not true. All Newton's 3rd law tells you is that whatever force the ground exerts on the rod (what you call the GRF), the rod will exert an equal and opposite force on the ground. As I've pointed out several times, the GRF does not necessarily equal the weight of the rod.
Doc Al,
Yes, sorry you did mention that the magnitude of GRF is not equal to the rod's weight.
To be precise maybe I should have said horizontal GRF is proportional to m.g.sin(Θ) rather than equal to it?I've seen hGRF = m.g.sin(Θ) mentioned before and looking at its derivation, they start with a ball rolling down a hill where Θ is the angle between the vertical and the contact point of the ball on the slope. They argue that the ball is 'rotated downhill' by gravity and that is proportional to the angle of the slope (which is also the deviation of the COM from the point of contact between the ball and the slope). They then make the leap to a horizontal surface and object leaning over to generate a horizontal component and back it up with a force diagram of a regular pendulum where the tangential force is m.g.sin(Θ), I'm not sure if an inverted pendulum works in the same way as a regular pendulum, but that is their assertion.
So, for a regular pendulum, is the tangential force m.g.sin(Θ)? Can that be applied to an inverted pendulum?
If it can, I guess we can say that the tangential force of the falling rod is m.g.sin(Θ) and then derive the horizontal force from there.
Alternatively, we could look at the approach you outlined, "You can calculate the GRF on the falling rod by first figuring out the acceleration of the rod's center of mass. Treat the rod as being in pure rotation about the contact point and make use of conservation of energy", but I would need some help to start on that.
Thanks for your help, it is really appreciated.
The component of the rod's weight perpendicular to the rod would be mg sinθ, if that's what you mean. That will be useful in finding the angular acceleration of the rod.
Sure.
How would you derive the horizontal component of the GRF from that?
Find the torque on the rod (using that perpendicular component of the rod's weight) and thus the angular acceleration. Use that to find the tangential acceleration of the center of mass. How would you find the radial acceleration?
Yes that's what I meant.
Doc Al said:
How would you derive the horizontal component of the GRF from [the tangential force]?
I presumed the horizontal component of the tangential force (the component of the rod's weight perpendicular to the rod) would be equal to the horizontal component of the GRF.
OK, so for a 2m long rod weighing 1kg, torque would be r * F = 1m * 1kg * g * sinθ = g sinθ
Angular acceleration = torque divided by moment of inertia
moment of inertia of the rod rotating around its end = ml^2 / 3 = 4/3
so angular acceleration = 0.75g sinθ
I'm not sure how to find the tangential acceleration of the center of mass. Would it just be equal to the angular acceleration at any particular instant? So if the instantaneous angle was 22.5*, the tangential acceleration would be 0.75g sinθ = 2.8
I presumed radial acceleration would be zero for a rod as its centre of mass does not travel radially towards the centre of rotation (its base).
I guess radial force would be mg cosθ?
I'm not very sure of that, so will of course appreciate corrections.
On what basis would you assume that?
OK.
Tangential acceleration is related to angular acceleration via at = alpha*r. (In your example, r = 1 m.)
That presumption is incorrect. Just because something isn't moving radially, doesn't mean that its acceleration has no radial component. Imagine something moving in a circle at some speed v. How would you calculate the radial--also know as centripetal--acceleration?
Yes, the radial component of the rod's weight would be mg cosθ.
My presumption "I presumed the horizontal component of the tangential force (the component of the rod's weight perpendicular to the rod) would be equal to the horizontal component of the GRF.", was based on Newton's second law. The force that creates the change in horizontal momentum must be the horizontal component of GRF as there are no other external forces acting with a horizontal component. I expect I was wrong as that ignores the radial part which also has a horizontal component.Carrying on the calculation from angular acceleration = 0.75g sinθ
You kindly supplied tangential a = alpha*r = alpha in the example.
For the radial acceleration, resolving radially we have:
F = ma
mg cosθ = ma
a = g cosθ
As you pointed out, this is an acceleration radially that produces the angular motion of the rod's COM.
Using the previous angle of 22.5* we see radial acceleration of 9.1 and tangential acceleration of 2.8
From there, is it possible to calculate the GRF? I tried by combining and resolving the accelerations both horizontally and vertically but the numbers did not look right.
Only two forces act on the rod: Gravity and the GRF. Since gravity acts vertically, only the horizontal component of the GRF creates the horizontal acceleration of the center of mass. That's why we're trying to find the acceleration of the center of mass.
OK.
F = ma
mg cosθ = ma
a = g cosθ
This won't work because you ignored one of the forces acting on the rod--the GRF also has a radial component. To use Newton's law you'd need the net radial force, not just the radial component of the weight.
No. What I wanted you to do was calculate the radial acceleration kinematically. Are you familiar with the standard formulas for centripetal acceleration? (You'll also need the hints I gave in post #13.)
Once you have the correct acceleration, then you can solve for the GRF using Newton's 2nd law.
I think I have some fundamental confusion here.
I understand that net external forces are needed to produce a change in momentum (Newton's second). I run into difficulty with cause and effect. To me it seems that the falling rod's weight causes GRF so to count the effect of gravity and the effect of GRF seems like counting the same force twice.
To help me resolve this confusion (I know I am wrong), can you explain in words how the GRF comes into being?
OK, so we have the acceleration from weight, a = g cosθ and the force from GRF. The GRF is what I am trying to calculate, so I cannot find the net radial force like this.
I've just had a look and I think F = m|v|^2 / R is the kinematic equation for centripetal force.
In the example, that gives F = |v|^2
Now we need to resolve v, so we can use the standard equation of motion v = u + at, but that would introduce the time variable into our equations which does not seem useful - I'm guessing there is a better approach?
It's certainly true that without gravity acting there would be no GRF. But they are two separate forces, and you must consider all forces when applying Newton's 2nd law.
Imagine yourself standing on the floor. If the only force on you were gravity, then you'd be accelerating downward at a = g. But the floor exerts a force on you to prevent you from pushing through it--that force is the GRF. If the floor is successful in stopping your potential motion, then your acceleration is zero and the GRF will equal your weight.
The case of the falling rod is a bit more complicated, since the rod is accelerating as it falls over. But we can calculate the acceleration and then use that to figure out the GRF via Newton's 2nd law.
The thing to do is calculate the acceleration directly, not via Newton's 2nd law.
For this problem we need the centripetal acceleration, which is given by:
ac = v²/r = ω²r
Indeed there is. Use conservation of energy. See my hints in post #13.
Doc Al,
Applying conservation of energy, I suppose we can say that the energy of the system at the start is its gravitic potential energy. At any point during the fall, the total energy will still be the same magnitude, but will be made up of a component of reduced gravitic potential energy and a component of kinetic energy.
Can a solution for the net force be established using kinetic and remaining potential energy at a particular point during the fall?
That's right.
Use conservation of energy to find the speed of the center of mass as a function of angle. (Use my earlier hints.) Then use that speed to figure out the radial acceleration. Since you already know how to find the tangential acceleration, you'll then have the full acceleration. Applying Newton's 2nd law will be the last step.
Finally got around to this again and I have worked out what may be a solution.
So, following your advice to find the velocity of the centre of mass as a function of angle:
We know that the energy E is constant such that the gravitic potential and kinetic are constant so E = mgh - 0.5mv^2
Before the rod falls, v is zero and h of COM = 1m, unit mass, so,
E = g
Therefore, g = mgh - 0.5mv^2
g = gh - 0.5v^2
Height can be expressed as a function of angle as h = rcosθ = cosθ, so,
g = gcosθ - 0.5v^2
and so the velocity as a function of angle is,
v^2 = 2g - 2gcosθ
If I am correct so far, the next step is to calculate the radial acceleration = v^2/r = v^2, so,
radial a = 2g - 2gcosθ
Tangential acceleration has already been calculated for the example as 0.75gsinθ
Total acceleration horizontally = tangential.cosθ - radial.cosθ
a = 0.75gsinθcosθ - cosθ(2g - 2gcosθ)
Unit mass so applying F= ma, horizontal force = 0.75gsinθcosθ - cosθ(2g - 2gcosθ)
Putting numbers into there gives results in line with what I would expect - is it right..?
  • · Replies 30 ·
  • · Replies 16 ·
