Separation of variables on 2nd order ode
koab1mjr
Hi all
Quick one, if one had an equation y' = x on could simply separate the variables and integrate. Now it the equation y'' = x you would use separation of variables what drives this?
Also
y'' =0. Is the same as. y''dx =0 dx
Why is this legal?Thanks in advance
Well, you can always multiply both sides of an equation by the same thing! So, yes, y''= 0 is the same as y''dx= 0dx= 0. And you can now integrate both sides of the equation, with respect to x, to get y'(x)= C where C is a constant of integration. But you did not really need to do that. You know, I hope, that if the derivative of a function is 0, then the function is a constant: if the second derivative of y is 0, the first derivative is a constant.
Ok re read what I wrote and my main question is not clear
Why is
D^2y/Dx^2 = 0 not the same as d^2y =0 dx^2
On one side u get a line on the other u get something else what is the rigorous explanation
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
