Sequences - Definition of convergence
4 replies · 2K views
tolove
Alright, I need some help with this.
an = [itex]\frac{1 - 5n^{4}}{n^{4} + 8n^{3}}[/itex]
To find the limit of convergence, use l'Hopital's Rule. The result will come out to
L = -5
From my book,
"The sequence {an} converges to the number L if for every positive number ε there corresponds an integer N such that for all n,
n > N → | an - L | < ε"
So, to check that L = -5 is true, substitute in? How do I show that L = -5 using this definition?
| an - L | < ε
| [itex]\frac{1 - 5n^{4}}{n^{4} + 8n^{3}}[/itex] - (-5) | < ε
Let n = 1, ε = 1
| [itex]\frac{1 - 5}{1 + 8}[/itex] + [itex]\frac{45}{9}[/itex]) | < ε = 1
[itex]\frac{41}{9}[/itex] < ε = 1, which is not true
Thank you for your time! This definition is very confusing to me for some reason.
That's not how the definition works. You have to take an arbitrary ##\epsilon > 0## and show that there exists an ##N \in \mathbb{N}## (which may or may not depend on ##\epsilon##) such that for all ##n> N## we have that ##\left | \frac{1 - 5n^{4}}{n^{4} + 8n^{3}} + 5 \right | < \epsilon##.
L = -5
From my book,
| an - L | < ε
Let n = 1, ε = 1
The basic idea is that for there is an N (large enough) so that the ε test will hold for all n > N.
Ohhh, so my e can be any positive number. For convergence, I must find an N.
thank you!
It might help to see a trivial example first. Consider the sequence given by ##a_n = \frac{1}{n}## and let ##\epsilon > 0##. Intuitively we can see that this converges to ##L = 0## but let's show that this is indeed the case. There exists an ##N\in \mathbb{N}## such that ##\epsilon N > 1## i.e. ##\frac{1}{N} < \epsilon##. Thus we have that ##\left | \frac{1}{n} \right | < \epsilon## for all ##n\geq N## meaning ##a_n\rightarrow 0##, as we would expect.
