Proof of Divergence: (-1)^n Sequence
In summary: So we have:(2=2 and L=-1)v(2=2 and L\neq -1)v(|1+L| = |1+L| and L=-1)v(||1+L| = |1+L| and L\neq -1)=> (True and False) or (True and True) or (|1+(-1)| =|-1| and True) or (|1+L| = |1+L| and False)=> False or True or (|0| =|-1| and True) or (|1+L| = |1+L| and False)=> True or (1=1 and True) or (|1
solakis1
422
Prove that the sequence :\(\displaystyle (-1)^n\) diverges by using the ε-definition of the limit of a sequence
Mathematics news on Phys.org
Ok, what is that definition? Can you give an explicit statement of the definition?
Re: Sequences
Yes.
[sp] A sequence of real Nos, \(\displaystyle x_n\), converges in \(\displaystyle R \) iff
There exists \(\displaystyle m\in R\) such that ,\(\displaystyle \forall\epsilon>0\),there exists a natural No \(\displaystyle k\),such that :
\(\displaystyle \forall n\geq k\Longrightarrow |x_n-m|<\epsilon\)
.......OR in complete formalization.......
\(\displaystyle \exists m\forall\epsilon[\epsilon>0\Longrightarrow\exists k(k\in N\wedge\forall n(n\geq k\Longrightarrow |x_n-m|<\epsilon))]\)
Hence for diversion one ​may use the negation of the above definition[/sp]
Re: Sequences
Very good!
So, use a proof by contradiction. If this sequence converges to, say, m, then, given any $\epsilon> 0$, there exist N such that, if n> N, $|a_n- m|< \epsilon$. Suppose $\epsilon$ were equal to, say, 1/2. Since for any odd n, $a_n= -1$, and for any even n, $a_n= 1$, no matter what N is there will exist some even number, $n_e$, and some odd number, $n_o$, both larger than N such that $|a_{n_e}- m|= |1- m|< 1/2$ and $|a_{n_0}- m|= |-1- m|< 1/2$.
The first of those says $-1/2< 1- m< 1/2$ so that $-3/2< m< -1/2$ and the second that $-1/2< -1- m< 1/2$ so that $-3/2< -m< -1/2$ and then $1/2< m< 3/2$. $-3/2< m< -1/2$ and $1/2< m< 3/2$ cannot both be true.
Is there any reason why this pretty standard "Calculus I" homework problem was posted in "Challenge Questions and Puzzles"?
Re: Sequences
Here is my solution.
Given a real number $L$, set $\epsilon = \max\{\lvert 1 - \lvert L\rvert\rvert,2\}$. Then $\epsilon > 0$. If $N$ is a positive integer, let $n$ be $2N+1$ if $L \neq -1$, and $2N$ if $L=-1$. Then $n > N$ and $\lvert (-1)^n - L\rvert \ge \epsilon$. Hence, the sequence $\{(-1)^n\}$ is divergent.
Re: Sequences
HallsofIvy said:
Very good!
[sp] if n>N,then is either even or odd and not both
For example if N =100 ,all the n>N are:
101 or 102 or 103 or 104 or 105 or 106 e.t.c,e.t.c
And not ,101 and,102 ,e.t.c,e.t.c , because n can take only one value
For n even we have :|1-m|<1/2 => 1/2<m<3/2 or
For n odd we have :|1+m|<1/2 => -3/2<m<-1/2
Hence if n>N => n is even or odd => (1/2<m<3/2)or (-3/2<m<-1/2) which is true
From propositional logic:
(pv q ,p=>r,q=>t) => r v t.............1
put:
p=n is even
q= n is odd
r= 1/2<m<3/2
t= -3/2<m<-1/2
Then by using the above law we end up with : (1/2<m<3/2) or (-3/2<m<-1/2) [/sp]
Re: Sequences
[sp] For n=2N+1, \(\displaystyle L\neq -1\) ,then n>N and \(\displaystyle |(-1)^n-L|=|-1-L|=|1+L|\)
So ε must be set :ε =min{|1+L|,2}
I think.[/sp]
Re: Sequences
I think.[/sp]
There was a typo, but $\min\{\lvert 1 + L\rvert, 2\}$ is not a valid choice for $\epsilon$ since then $\epsilon = 0$ when $L = -1$. In any case, I meant to have $\epsilon = \epsilon(L) := \lvert 1 + L\rvert$ for $L \neq -1$ and $2$ for $L = -1$. It is then clear that for each positive integer $n$, $\lvert (-1)^{2n} - (-1)\rvert = 2 = \epsilon(-1)$ and $\lvert (-1)^{2n+1} - L\rvert = \lvert 1 + L\rvert = \epsilon(L)$ (when $L \neq -1$)
Re: Sequences
[sp] Given L,choose ε=min{|1-L|,2},then for any natular No L,put n=2N for L=-1 and n=2N+2 for \(\displaystyle L\neq -1\).
Then we have for the 1st case n>N and \(\displaystyle |(-1)^n-L|=|1-(-1)|=2\geq\epsilon\) and thus \(\displaystyle |(-1)^n-L|\geq\epsilon\)
For the 2nd case n>N and \(\displaystyle |(-1)^n-L| =|1-L|\geq\epsilon\) thus \(\displaystyle |(-1)^n-L|\geq\epsilon\)
On the other hand if we choose ε=2 or ε=|1+L| ,since we also have L=-1 or \(\displaystyle L\neq -1\) we have to examine 4 cases as dictated by propositional logic.
(pvq)and (rvt)=> (p and r)v(p and t)v (q and r) v (q and t),where:
p= (ε=2)
q= (ε= |1+L|)
r=(L=-1)
t= (\(\displaystyle L\neq -1\)) [/sp]
Related to Proof of Divergence: (-1)^n Sequence
1. What is the Proof of Divergence for the (-1)^n sequence?
The proof of divergence for the (-1)^n sequence is a mathematical proof that shows that the sequence does not converge to a specific limit. In other words, the values in the sequence do not approach a single number as n (the position in the sequence) gets larger.
2. How is the Proof of Divergence for the (-1)^n sequence different from other sequences?
The (-1)^n sequence is different from other sequences because it alternates between positive and negative values as n increases. This makes it impossible to approach a single limit and therefore, the sequence diverges.
3. Is there a specific formula for the Proof of Divergence for the (-1)^n sequence?
Yes, the formula for the Proof of Divergence for the (-1)^n sequence is lim n → ∞ (-1)^n = DNE, which stands for "does not exist". This means that the limit of the sequence does not exist.
4. How is the Proof of Divergence for the (-1)^n sequence used in real-world applications?
The Proof of Divergence for the (-1)^n sequence is used in real-world applications to show that certain scenarios or systems do not have a definite outcome or limit. For example, it can be used in economics to show that a fluctuating market does not have a predictable end point.
5. Can the Proof of Divergence for the (-1)^n sequence be applied to other sequences?
Yes, the concept of proving divergence can be applied to other sequences as well. However, the specific formula and steps may vary depending on the sequence. It is important to understand the characteristics of the sequence and use the appropriate methods to prove its divergence.
  • General Math
  • General Math
  • General Math
  • General Math
