Series Circuit: 10 Ohm Resistor, Bulb, 12V Source
9 replies · 4K views
ElectricSlide
A 10 ohm resistor in a series with a bulb and a 12v source.
a) If the 8.0V is across the bulb, what is the voltage across the resistor?
I wrote 4v, is this correct?
b) What is the current in the circuit? I wrote 1.5A, is this correct?
c) What is the resistance of the bulb? Could someone please tell me the formula I would need to know to complete this question?
Redbelly98 said:
a) correct
b) no. how did you get 1.5A?
c) what formula do you know of that deals with voltage, current, and resistance?
p.s. welcome to PF.
for question " b) " i got "I = V/R" from Ohm's Law. I realize I mistakenly wrote 1.5A, I meant 1.2A, is that incorrect still?
for question "c)" I don't see anything that pertains to it other than Ohm's law, " R = V/I " but I don't have the current, so i do not understand how to solve it.
Would the correct way to do it be " R = 4/1.2 " ??
Redbelly98 said:
b) Okay, correct formula. What are you using for V and R that gives you 1.5A?
c)
See part (b)
you said part b) was wrong though.. or did you not read it after I re-edited it?
b)
Umm, 1.2A is also not right. (I did miss your edit.) Apparently you are saying
12 V / 10 Ω = 1.2 A
But it is wrong (for this circuit) to use 12V and 10Ω together like that.
What do you know about the current through each component, given that they are in series?
c)
Once you have gotten a correct answer for (b), you can use that information.
Redbelly98 said:
b)
12 V / 10 Ω = 1.2 A
Clearly not much.. lol
less current means more voltage or that it gets reduced?
You have voltage and resistance of the resistor, so you can get the current through it.
oh so it would be I = 4/10 which is .4?
