Series Connected D.C Motor Characteristics
  • Thread starter Thread starter 1988ajk
    Motor Series
A series connected D.C. motor exhibits a hyperbolic torque-speed relationship rather than a linear one, with speed decreasing as torque increases. The motor provides excellent starting torque due to the low resistance of the series field winding, which saturates quickly. However, as armature current increases from no load to full load, the torque diminishes. This behavior contrasts with permanent magnet motors, which are presumed to have similar characteristics since the magnets perform a comparable function to windings. Overall, series D.C. motors excel in starting torque but struggle with speed regulation under varying loads.
1988ajk
Hi all,
Please excuse me for such a simple question, I am a predominantly a mechanical engineer.
Does a series connected D.C Motor have a linear speed/torque relationship or a curve?
I am aware that both have speed (RPM) decreasing as torque (Nm) increases.
Many thanks in advance!
Many thanks,
the last post has cleared up some ambiguous notes I have.
Since your series field is in series with your armature, and has a very low resistance, about .4 ohms... it saturates very quickly providing maximum flux on relatively low provided current. For that reason, the motor has Amazing starting torque, but since the winding is saturated early it produces less and less torque as armature current is applied form no load to full load.
In summary, the motor has excellent torque on starting, but has poor speed regulation from no load to full load (as armature current is applied)
say if the d.c motor were a permanent magnet type, would this have the same characteristics?
I presume that they would stay the same, as the magnets do the same 'job' as windings.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
