Series cos(x)^n/3^n boundary question
  • Thread starter Thread starter NastyAccident
    Boundary Series
NastyAccident
\sum^{infinity}_{n=0}\frac{cos(x)^n}{3^n}
Find the values of x for which the series converges.
(z,p)
Find the sum of the series for those values of x.
Geometric Series Sum (a/(1-r))
Geometric Series a*r^n
I believe I have b correct, so I'm going to lead with b solution:
\sum^{infinity}_{n=0}\frac{cos(x)^{n}}{3^{n}}
\sum^{infinity}_{n=0}(\frac{cos(x)}{3})^{n}
This series is a geometric series a = 1 and r = \frac{cos(x)}{3}.
Since, \left|r\right|=\left|\frac{cos(x)}{3}\right|<1, it converges and gives
\frac{1}{1-\frac{cos(x)}{3}}
Attempt at a.
Since the series starts at n = 0, the first term, is always going to be 1. Find the values of x for which the series converges. Thus,
-1<\frac{cos(x)}{3}<1
-3<cos(x)<3
arccos(-3)<x<arccos(3)
But, the issue is the the domain of arccos(x) is -1<x<1... I'm not necessarily sure what I'm doing wrong for this particular problem.
I've tried -1/3 (since the range of cosine is -1 to 1) and -3, both were incorrect.
As always any help or further explanation is welcome and will be greatly appreciated!
NastyAccident
hi NastyAccident, may computer is being a bit silly with tex to read, but hope this helps
first does the series below converge?
\sum^{infinity}_{n=0}\frac{1}{3^{n}}
then maybe have a think about absolute convergence & the absolute value of cos
What you did at first is correct and completely answers the question: that is a geometric series in cos(x) and converges as long as -1< cos(x)/3< 1 which is the same as -3< cos(x)< 3. Since the range of cosine is only -1 to 1, that converges for all x and the sum is
\frac{1}{1- \frac{cos(x)}{3}}= \frac{3}{3- cos(x)}
Ahh! So, I should of stopped on the step before I took the arccos of each side.
Now, a new question that I have is why did you just leave it as cos(x)? The normal thought is to create an inequality like -1<x<1 that has x solely in the middle. Since there was a trigonometry function, is it just custom to have an inequality like -1<cos(x)<1?
From after that step, I can easily understand everything else: such as, cos(x) range is from -1 to 1 and range for this particular series would be [-1/3,1/3]. This fits inside the -3<cos(x)<3 inequality.
Many thanks for your help Ivy!
NastyAccident
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
