Series expansion of logarithmic function
To find the first three non-zero terms in the series expansion of ln(5+p) for small values of p, it is suggested to rewrite the function as ln(5[1+(p/5)]). This allows the use of logarithmic properties to separate the terms. The series expansion can then be applied to the term ln(1+(p/5)), which is suitable for small p. The accuracy of the expansion diminishes as p moves away from -4, but the focus remains on deriving the first three non-zero terms. The approach emphasizes the importance of correctly applying logarithmic identities for effective expansion.
seboastien
Find first three non zero terms in series expansion where the argument of funstion is small
ln(5+p)
The only way I could think how to do this is by saying ln(5+p) = ln(1+(4+p)) and expanding to
(4+p)- 1/2(4+p)^2 + 1/3(4+p)^3 - ... however, I imagine that this would only work if p was approx -4.
Come on guys! I really need to know how to do this!
ln(5+p)
Well, the accuracy, for any finite polynomial expansion, deteriorates as p gets farther from -4 but is the accuracy really relevant? You are only asked to "Find first three non zero terms".
How do I find the first three non-zero terms of ln(5+p), I'm pretty sure that my answer is wrong.
You'll want to write this as ln( 5 [ 1+(p/5) ] ) ; then use the properties of logarithms to write it as two terms, one of which is the term you would do the series expansion for.
Thank you
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
