How Does Setting c=1 Affect g's Value?
  • Thread starter Thread starter quasar987
    Work
quasar987
In the usual units where c=3x10^8 m/s and g=10m/s², what is g in the units where c=1?
I said, let's redefine the meter like so: \tilde{m}:=3\times 10^8 m so that now c=1\tilde{m}/s. And then I calculated g by substituting m for (3\times 10^8)^{-1}\tilde{m}... but is this what the question is asking? Because I might as well have chosen to derefine the seconds and since it is s² that pops in in the units of g, the answer would have been different. And the question seems to talk like there is only one answer: "what is g in the units where c=1?"
The question is, indeed, ill-posed.
Perhaps you are meant to use a standard meter as your new length scale as well, but who knows?
Perhaps you are meant to use the second as your new time scale..
In the context of interstellar travel with g = 1, it is often convenient to use years and lightyears, and g then also has a fairly nice value.
Eeh, you meant c=1, George?
Of course using both c=1 and g=1 make those two values very nice, indeed..
Yikes!
Instead of "with g = 1", I meant "with proper acceleration a = g".
Thanks arildno.
c=1 LY/Y, as any reader of the New York Times knows.
Just calculate g in LY/Y^2. That proves that God exists,
and God is 1.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
