Shear stress on a bar with a bend
The discussion focuses on calculating the shear stress (\tauxy) at point A on a solid round bar that is fixed at one end and bends 90 degrees. The relevant equations used are the torsion formula (\tau = Tc/J) and the beam shear formula (\tau = VQ/It). The user provided specific values for forces and dimensions, resulting in a calculated torsion shear of -16900 psi and a beam shear of -2844 psi. The total shear stress was computed as the difference between these two values.
  • Understanding of shear stress calculations in mechanics
  • Familiarity with torsion and beam shear equations
  • Knowledge of material properties and cross-sectional geometry
  • Ability to apply Cartesian coordinates in force analysis
  • Review the derivation and application of the torsion formula in Mechanics of Materials
  • Study beam shear calculations and the significance of the centroid in cross-sectional analysis
  • Explore examples of shear stress in bent beams and fixed supports
  • Investigate online resources or textbooks that provide detailed explanations of shear stress problems
Students in engineering mechanics, particularly those studying material strength and structural analysis, as well as professionals involved in mechanical design and analysis of structural components.
triindiglo
I have encountered this problem several times in class, but have never really understood it. There is a solid round bar that is fixed on one end, and that bends 90 degrees a ways down. At the free end of the bar there are forces applied in each Cartesian direction.
Like this: http://farm4.static.flickr.com/3448/4559398860_d6c6e250a0_o.jpg"
The question is to determine the shear stress \tauxy at point A (on the outer edge of the tube, radially parallel to the z-axis).
Torsion - \tau = Tc/J
Beam - \tau = VQ/It
I plug in my values in the above equations, and add them up depending on the shear direction, but I don't seem to get the right answer.
I'm hoping someone can help me with the general idea for this type of problem or point me to a website that explains it clearly.
Thanks!
What values are you using for the torque and the shear force?
Here is what I tried:
Fx=500lbf
Fy=-800lbf
T=Fy14in
c=r (radius)
J=pi*r4/4
which gives torsion shear=-16900psi
V=Fy
Q=y'A'
y'=r
A'=pi*r2/2
t=r
with beam shear=-2844psi
total shear (xy)=torsion shear-beam shear
It's been a while since I was actually in Mechanics of Materials, so that might be way wrong though :).
It's been a while for me too, but isn't y' the distance to the centroid of the top or bottom half of the cross section?
ah, yes you are right. Unfortunately I don't have the correct answer in front of me anymore so I can't check if that's all that is wrong.
Hopefully the other stuff looks right though?
Yep, the torsion part looks good.
