How is shear stress related to shear rate in aerodynamic applications?
Shear stress in aerodynamic applications is directly proportional to the shear rate, as established in J. Anderson's "Fundamentals of Aerodynamics." This relationship holds true for Newtonian fluids, such as air, where dynamic viscosity remains constant. The discussion highlights the need for a quantitative molecular explanation, which can be found in chapter 1 of "Transport Phenomena" by Bird, Stewart, and Lightfoot. Additionally, the complexities of calculating velocity gradients at the surface of an aircraft are acknowledged, emphasizing the non-linear nature of these gradients compared to Couette flow.
  • Understanding of Newtonian fluids and dynamic viscosity
  • Familiarity with shear stress and shear rate concepts
  • Knowledge of boundary layer theory in fluid dynamics
  • Basic principles of inviscid flow analysis
  • Study chapter 1 of "Transport Phenomena" by Bird, Stewart, and Lightfoot for molecular explanations of shear stress
  • Research the calculation of velocity gradients in non-linear flow scenarios
  • Explore advanced boundary layer theory and its applications in aerodynamics
  • Investigate the relationship between temperature gradients and shear stress in fluid dynamics
Aerodynamic engineers, fluid dynamicists, and students studying aerodynamics who seek to deepen their understanding of shear stress and shear rate relationships in Newtonian fluids.
MaxKang
Hello everyone,
I came across this in J. Anderson's book "Fundamentals of Aerodynamics".
"For the type of gases and liquids of interest in aerodynamic applications, the value of the shear stress at a point on a streamline is proportional to the spatial rate of change of velocity normal to the streamline at that point"
1. I am aware that air is a type of Newtonian fluid where its dynamic viscosity remains constant. Could someone why the magnitude of shear stress happen to be proportional to that of the shear rate(or Velocity Gradient)? A lot of books and Youtube videos merely say this is experimental and do not quite explain why this is the case.
2. I also read "Conventional boundary layer analysis assumes that the flow conditions at the outer edge of the boundary layer are the same as the surface flow conditions from an inviscid flow analysis" so in order to find the flow velocity at the outer edge of the boundary layer, I would assume the flow is inviscid and use the velocity right on the surface for the outer edge velocity. My question is, then how do I go about computing the velocity gradient(dv/dy) right on the surface? The velocity gradient on the surface of an aircraft is not linear unlike the Couette flow so I don't think I can use the the speed at the outer edge of the boundary layer(right adjacent to free stream) to find the theoretical value of the shear stress.
I would like to know how it's done for temperature as well.
Thank you!
Can you please break this down into several threads. There are too many questions here to answer all in one place.
I will answer your first question, however. If you are asking for a quantitative molecular explanation of why the shear stress is proportional to the shear rate, see chapter 1 of Bird, Stewart, and Lightfoot, Transport Phenomena.
Thank you so much! I will read up on it :)
