Why is the expression for sheet resistance given without demonstration?
The forum discussion centers on the derivation of the expression for sheet resistance, R_{\square}, of a uniform conductor characterized by length L, width W = L, and thickness t. The expression is given as R_{\square} = \frac{\sqrt{\frac{\pi f \mu}{\sigma}}}{1 - e^{-t/\delta}} = \frac{1}{\sigma \delta} \frac{1}{1 - e^{-t/\delta}}, where f is frequency, μ is magnetic permeability, σ is conductivity, and δ is penetration depth. Participants explore the relationship between sheet resistance and impedance, noting discrepancies in derived values and discussing the implications of power dissipation in the context of Poynting's theorem. The discussion concludes that while different methods yield similar asymptotic behaviors, the exact expressions differ under certain conditions.
  • Understanding of electromagnetic theory, specifically Poynting's theorem.
  • Familiarity with concepts of sheet resistance and its mathematical representation.
  • Knowledge of complex impedance and its real part in electrical circuits.
  • Basic principles of conductivity and magnetic permeability in materials.
  • Study the derivation of sheet resistance in uniform conductors using electromagnetic theory.
  • Learn about the application of Poynting's theorem in calculating power dissipation in conductors.
  • Research the relationship between impedance and resistance in AC circuits, focusing on complex numbers.
  • Explore the significance of penetration depth (δ) in conductive materials at varying frequencies.
Electrical engineers, physicists, and materials scientists interested in the behavior of conductors in AC circuits, particularly those focusing on sheet resistance and its derivation.
EmilyRuck
Hello!
I have in my notes an expression for the sheet resistance of a uniform conductor with length L, width W = L and thickness t. It is
R_{\square} = \displaystyle \frac{\sqrt{\displaystyle \frac{\pi f \mu}{\sigma}}}{1 - e^{-t/\delta}} = \displaystyle \frac{1}{\sigma \delta} \frac{1}{1 - e^{-t/\delta}}
where f is the frequency of the signal, \mu is the magnetic permeability, \sigma is conductivity of the conductor and \delta is its penetration depth.
This is given without any demonstration and it seems a standard expression. Do you know it or something similar? How can it be obtained?
If you don't have an answer, but you have some links or reference books, they will be useful as well!
Thank you anyway,
Emily
I will try to add some details, hoping that it will be useful.
Suppose that the thickness is along the x direction and the width is along y. The current density across a section can be expressed as
J(x) = J_0 e^{-(1 + j)x/\delta}
so it is supposed to be uniform along y.
The sheet resistance or R_{\square} should be obtained through the total current flowing through a section of the conductor and the voltage across a length L:
I = \displaystyle \int_{0}^{W = L} \int_{0}^{t} J(x)dxdy = L \int_{0}^{t} J(x)dx = - L J_0 \frac{\delta}{1 + j} \left[ e^{-(1 + j)t/\delta} - 1 \right]
Knowing that J_0 = - \sigma E_0 and that E_0 = V_0 / L we have
I = \sigma V_0 \frac{\delta}{1 + j} \left[ 1 - e^{-(1 + j)t/\delta} \right]
The impedance is
Z = \displaystyle \frac{V_0}{I} = \frac{1 + j}{\sigma \delta \left[ 1 - e^{-(1 + j)t/\delta} \right]}
The R_{\square} must be the real part of Z.
Even noting that
\frac{1}{\sigma \delta} = \sqrt{\displaystyle \frac{\pi f \mu}{\sigma}}
the real part of Z does not coincide with the R_{\square} of the original post. It is a more complicated expression.
Emily,
My hunch is that this is defined in terms of power dissipation. From Poynting's theorem, the power dissipated would be
<br /> P = \frac{1}{2} \Re \int dv \, \mathbf{E}\cdot\mathbf{J}^\ast<br />
For power per unit area you would only integrate along your x direction. Using
<br /> E(x) = E_0 e^{-(1 + j)x/\delta}<br />
<br /> J(x) = \sigma E_0 e^{-(1 + j)x/\delta}<br />
doing the integral and setting that expression equal to E_0^2/2 R may get you the expression you want, but it will have an extra factor of 2 in the exponent when compared to your original formula.
jason
Likes EmilyRuck
Just one more thought. To apply such a concept it may make more sense to write E_0 in terms of H_0, then set the integral equal to |H_0|^2 R_{\square}. I'm thinking this may be more practical since we usually use PEC boundary conditions on good conductors, then use the surface H to estimate the surface current and hence losses.
Thank you for your very useful observations.
I tried to compute R_{\square} from the power, as you suggested: with L = W = 1. The result, as you predicted, is
R_{\square} = \displaystyle \frac{2}{\sigma \delta (1 - e^{-2t/\delta})}
It is definitely better than mine, even if not exactly what I expected.
A question: why the R_{\square} obtained from power is different from the R_{\square} obtained as \Re(Z)? Should not they be equal?
The curious thing is that the asymptotical behaviour of both
R_{\square} = \displaystyle \frac{1}{\sigma \delta (1 - e^{-t/\delta})} (1)
and
R_{\square} = \Re(Z) = \Re \left \{ \displaystyle \frac{1 + j}{\sigma \delta \left[ 1 - e^{-(1 + j)t/\delta} \right] } \right \} (2)
is the same.
For t \ll \delta, that is \omega \to 0, (1) becomes
R_{\square} \simeq \displaystyle \frac{1}{\sigma \delta (1 - (1 - t/\delta))} = \frac{1}{\sigma t}
and (2) is
R_{\square} = \Re \left \{ \displaystyle \frac{1 + j}{\sigma \delta \left[ 1 - e^{-(1 + j)t/\delta} \right] } \right \} \simeq \Re \left \{ \displaystyle \frac{1 + j}{\sigma \delta \left[ 1 - (1 -(1 + j)t/\delta ) \right]} \right \} = \frac{1}{\sigma t}
the same!
For t \gg \delta, that is \omega \to \infty, (1) becomes
R_{\square} \simeq \displaystyle \frac{1}{\sigma \delta}
and (2) is
R_{\square} \simeq \Re \left \{ \displaystyle \frac{1 + j}{\sigma \delta } \right \} = \displaystyle \frac{1}{\sigma \delta}
Again, the same.
This is the second doubt arousen: why is such a behaviour possible?P. S.
I didn't thought about H field, but up to now I preferred to mantain the E-point-of-view.
Thread 'Colors in a plasma globe'
I have a common plasma globe with blue streamers and orange pads at both ends. The orange light is emitted by neon and the blue light is presumably emitted by argon and xenon. Why are the streamers blue while the pads at both ends are orange? A plasma globe's electric field is strong near the central electrode, decreasing with distance, so I would not expect the orange color at both ends.
28K
  • · Replies 29 ·
