Shell method versus disk method
The discussion focuses on the confusion between using the shell method and the disk method for calculating the volume of a solid generated by revolving a region around the y-axis. The user initially applies the disk method with the integral π∫y^4 dy from 0 to 2, and the shell method with 2π∫x(2-√x)dx, but receives different results. A key point raised is that the limits for the shell method should be adjusted from 0 to 4 instead of 0 to 2. This adjustment resolves the discrepancy in the volume calculations. Understanding the correct limits and method application is crucial for accurate volume determination.
fiziksfun
I'm confused when to use the shell method vs. the disk method
Specifically in this problem:
If the region encolsed by the y-axis, the line y=2 and the curve y=\sqrt{x} is revolved around the y-axis, the volume of the solid generated is:
However when I use the shell method and the disk method I get different answers
Can someone tell me what I'm doing wrong?
Disk Method:
\pi \inty^4 dy evaluated from 0 to 2
Shell Method:
2\pi\intx(2-\sqrt{x})dx
Help please!
I got the same answer. Remember the second integral is from 0 to 4 not 0 to 2.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
