Inertia humming bird is hovering in a car
In a discussion about whether a hummingbird hovering in a car would fly into the windshield when the car suddenly stops, participants debated the dynamics of motion and air pressure. It was established that when the car brakes, the air inside the vehicle shifts forward, creating a vacuum effect in the back. This could potentially cause the hummingbird to lurch forward, similar to how a person would move without a seatbelt. However, the hummingbird's ability to rapidly adjust its position by beating its wings may prevent it from hitting the windshield. Comparisons were made to a helium balloon, which behaves oppositely due to differences in buoyancy and density. Ultimately, while the bird might experience a forward motion, its agility could allow it to avoid collision with the windshield under normal braking conditions.
socialcoma
if a humming bird is hovering in a car going at a constant rate, and the car comes to a sudden stop, will the bird fly into the windsheild?
Yes! I think... :p
Interesting side note:
If you had a helium filled balloon in your car and attached it to the floor, when you hit the brakes it will actually go BACKWARDS. If you accelerate, it moves forwards, etc. The movement of the balloon is the opposite of what you would expect. This is due to the movement or air and air density in the car.
Ok..well for the humming bird...when it is floating, it is staying in place in the "bubble" of air in the car...when the car brakes, in order for the hummingbird to hit the windshield, all that air would have to be smashed forward...which would leave a vacuum in the back and then that would be filled up...so wouldn't it get really windy in the car whenever u stop?(assuming that this is all with the windows closed)
yes, all of this with the window closed
Do *YOU* fly toward the windshield when the car suddenly stops? (hint: why are you wearning a seatbelt?) There's your answer.
The hummingbird isn't floating - its FLYING. Huge difference.
LOL. I think we're making this question tougher than it is.
I think not. Like the hellium balloon, the humming bird rides the air within the vehicle. Admittedly, the humming bird is less bouyant than the balloon, but it is also far less massive than a person. Additionally, the bird is not a passive passenger of the air currents, like the balloon. On the contrary, it beats its wings something on the order of 20-30 times per second. This gives it many opportunities for "course correction". I don't know what their exact manuevering specs are, but I've seen them pull some serious G's.
So, although the bird might tend to "LURCH forward" a bit, I doubt you could get it to hit the windscreen simply by breaking. Maybe by crashing the car into a wall or something.
i don't mean will the bird actually hit the windsheil, i was just trying to find out if the bird would lurch forward
Of course, bird will slam into windshield. Braking is equivalent to increase in g (and tilting it forward).
Buoyancy depends on the density of an object, not its mass. As the humming bird has a higher density than air but the helium balloon a lower density, they will not behave identically, i.e. the humming bird will fly against the windshield if you brake the car (unless it can react very quickly and brake as well).
