Shim Inductor in Phase Shifted Full Bridge topology
The discussion centers on the role and functionality of the shim inductor within the Phase-Shifted Full Bridge (PSFB) topology, particularly regarding its impact on efficiency and switching losses. Participants explore theoretical and practical aspects of its implementation and effects on circuit performance.
  • Some participants inquire about the purpose of the shim inductor and its function in improving efficiency in PSFB circuits.
  • One participant notes a significant efficiency improvement after adding a shim inductor but expresses uncertainty about the underlying reasons.
  • Several participants reference a TI Application Report to provide context and schematics related to the discussion.
  • There is a suggestion that the shim inductor may help achieve Zero Voltage Transition (ZVT) for MOSFETs, thereby minimizing switching losses.
  • One participant discusses the interaction between leakage inductance and output load, suggesting that adding series inductance can relieve switches of in-phase charge transfer, potentially leading to resonant energy circulation.
  • Another participant elaborates on the timing of FET switching in relation to the shim inductor, explaining how it can facilitate Zero Voltage Switching (ZVS) and reduce turn-on losses.
  • There is a mention of the standard transformer model and its relation to the shim inductor's function, with some disagreement on the configuration of primary leakage inductance.
Participants express a range of views on the shim inductor's role, with some agreeing on its benefits for efficiency and switching losses, while others raise questions about its exact function and the implications of leakage inductance. The discussion remains unresolved regarding the specific mechanisms at play.
Some participants reference specific figures and descriptions from the TI Application Report, indicating that their understanding may depend on those materials. There are also mentions of missing attachments and diagrams that could clarify points made in the discussion.
Dextrine
What is the purpose of the shim inductor and how exactly does it function in PSFB topology? I noticed that I had dramatically improved efficiency when I added a shim inductor to my circuit, not too sure how or why this works though.
Could you please post a schematic and link to more information about what you are asking? That would help a lot. Thanks.
Sure,
Here in this document, on page 2. Ls is (plus Db and Dc). Made my circuit have much better efficiency.
Baluncore said:
See fig. 9, and the description below on page 7 of TI Application Report;
"Phase-Shifted Full-Bridge, Zero-Voltage Transition Design Considerations".
http://www.tij.co.jp/jp/lit/an/slua107a/slua107a.pdf
Hmmm, so it's really just to increase inductance? How does that help with efficiency? How strange. Also, how strange that I've never seen this application sheet and the 28950 is the controller I've been using! Thanks for the reply.
I think the problem is that the “leakage inductance” of a transformer primary is in parallel with and so is effectively short circuited by the (backward transformed) output load. That makes it “hard” to drive. By adding series inductance sufficient to cancel switch capacitance it relieves the switches of that in-phase charge transfer twice per cycle. It turns the real losses into a resonant energy circulation without real power losses.
Your attachment did not make it to the post. Drag and drop onto the post when editing.
Thanks, that makes sense. I'll keep trying to understand your post better. Here is the picture (hopefully it makes it)
Maybe that efficiency improvement resides in achieving a condition of (or near to) Zero Voltage Transition of Mosfets, thus minimizing switching losses.
The standard transformer model is seen here: https://en.wikipedia.org/wiki/Transformer
I've reproduced it here with an addition showing a load on the secondary Zs, with its transformed version Zp shown on the primary. The primary leakage inductance is designated Xp, and it would seem to be in series with the transformed secondary load, not in parallel.
@Zzaimon seems to have gotten it right. To expand:
The usual timing for the FETs would be A and D turn on and off simultaneously, with B and C switching simultaneously while A,D are off. And vice versa.
from figure 3
The "new" approach has the controller chip modifying the switching times.
Notice that A,D are not switching simultaneously, and neither are B,C.
from figure 4.
In this case FET 'D' switches off before FET 'A' does; and the added inductor in the primary reduces the ringing frequency in the primary circuit.
The ringing frequency is chosen so that the voltage waveform at the FET 'D' Drain (FET 'C' Source) terminal is at its positive peak (the supply voltage) when FET 'C' is switched On. Since there is zero voltage across FET 'C' there is no turn-on loss.
And with 'C' On, FET 'A' is now turned Off.
(Whew!)
Now the Primary circuit is still in its first ringing cycle. Since 'C' is On, the right end of the primary is held at supply voltage and the ringing causes the left end of the Primary to be relatively Negative. At some point the left end of the primary is at the Negative supply voltage. When this occurs there is no voltage across FET 'B', so it is now turned on with zero turn-on loss.
Synopsis:
Starting with FETs 'A' and 'D' on, primary current flowing.
D turns Off
When the ringing voltage rises to the supply voltage, turn On 'C'
Turn Off 'A'
With ringing voltage at Negative supply, Turn On 'B'
Primary polarity switching is now complete.
That's how you get Zero Voltage Switching (ZVS) with an H-bridge power supply.
Rather clever, thanks for the thread.
Cheers,
Tom
p.s. All of this was taken from the TI App Note with a few details skipped... and fewer words to wade thru.
  • · Replies 17 ·
  • · Replies 37 ·
  • · Replies 27 ·
