Should I Normalize My Data for Host Ranking?
  • Thread starter Thread starter xeon123
    Data Normalize
Normalizing data for host ranking can enhance the accuracy of predictions derived from measures like transmission and computation time. The effectiveness of normalization depends on the decision-making context and the specific goals of the analysis. A cost function is essential to determine the appropriate weight for each measure, guiding the normalization process. Without proper weighting, the combined measures may not provide a reliable ranking. Ultimately, normalization should align with the intended outcomes of the ranking system.
xeon123
I have 2 measures that I am using to rank terms that I get them by prediction (using linear regression). They are the time to transmit X bytes and the time to compute the X bytes. I do the prediction if I execute in host A, B, and C. I add the 2 measures and rank the hosts. I think adding these 2 measures are not enough. Should I normalize these 2 measures?
Mathematics news on Phys.org
It depends what decision will be based on the result. You need a cost function which tells you how much weight to give to each measure.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
