Should I write my will now? Going to use 1.5 moles of t-buLi tomorrow.
  • Thread starter Thread starter gravenewworld
    Moles
The discussion centers around the use of t-butyllithium (t-BuLi) in chemical reactions, highlighting its highly reactive nature and the associated safety precautions. Users emphasize the importance of working in pairs during the addition or manipulation phases and having a fire extinguisher readily available due to the risk of fire, particularly if t-BuLi is improperly handled. A specific incident is recounted where a stopcock failure led to flames, underscoring the need for secure fittings, with recommendations favoring ground glass stopcocks over Teflon due to potential risks. Participants share methods for minimizing air exposure during transfers, such as using a cannula, and caution against the dangers of aggressive bases reacting with Teflon, which can lead to hazardous situations. Overall, the conversation stresses the importance of safety and proper technique when handling reactive chemicals like t-BuLi.
gravenewworld
And the solvent for the reaction is going to be 2.5 liters of ether. :bugeye:
I hear the t-buLi becomes an instant flame thrower if it is shot out of a syringe.
Seriously though, anyone else use this stuff before?
Chemistry news on Phys.org
I've used it on a smaller scale. It's a doozie! Don't work alone during the addition or manipulation phase of the reaction. Have your fire extinguisher handy as well.
Are you going to transfer by cannula from the stock bottle to your dropping funnel or reaction vessel? There is a way to minimize the needle's exposure to the air. Let me know if you don't know of a method.
Yeah we used a cannula to transfer 800 mL of 1.7 M t-butylli solution to an addition funnel. Everything was going fine until I started to try to drip in the t-butyli. Apparently the stopcock wasn't tightened extremely well and flames started coming out of it. We got lucky because a spark just missed our acetone/dry ice bath by like an inch (and there were probably 3 L of acetone in the bath). The fire stopped quickly though and it pretty much sealed itself.
You were using a teflon stopcock? That's pretty risky. I would use a ground glass stopcock with greased joints for any really air sensitive stuff. I've also noticed that aggressive bases react with teflon a bit turning them slightly brown. That can't be good. If you did have a fire, teflon melts! Big effects follow...
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
