Should the poles at the end of each magnet be similar?
  • Thread starter Thread starter arety33
    Magnet Poles
For effective magnetism when using two magnets connected by paramagnetic material in a U-shape, the poles at each end should be dissimilar. Opposite polarity allows the magnetic field to flow from one magnet to the other, enhancing the attraction of iron shavings. If the magnets have the same polarity, the magnetic fields will cancel each other out, resulting in ineffective pickup of the iron. Experimentation supports that using one polarity aligns the magnetic domains in the iron, while differing polarities disrupt this alignment. Thus, for optimal performance, magnets should have opposite poles at their ends.
arety33
Hi, I have a question about magnetism.
If 2 magnets are used to pick up iron shavings, and the magnet are connect with paramagnetic material and turned into a U-shape.
Should the poles at the end of each magnet by similar or dissimilar to pick up the iron shavings most effectively?
They should be of opposite polarity so that the B field in the iron goes from one magnet to the other. If they wer of the same polarity, B in the iron would tend to cancel. Try it experimentally.
I think the domains the the iron field at the beginning is random oriented, but if one polarity is used to pick up the iron shavings, the domains will all point to the same direction. But if the other magnet is different polarity, the domains will begin to point in the other direction and cancel out the other domains. Then the iron shavings will not be picked up.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
