Shouldn't the operator be applied to both the wf anD its modulus?
jshrager
Why is it:
$$ \langle A \rangle = \int dV ~ \psi^* (\hat{A} \psi) $$
As opposed to:
$$ \langle A \rangle = \int dV ~ (\hat{A} \psi^*) (\hat{A} \psi) $$
The op can substantially change the wf, so it would seem to make more mathematical sense (at least from a linear algebra pov) to operate on both the wf and its mod, otherwise, as we do it now (first expr) you're getting a very odd product. Is this is a property of the way that wfs are formulated? Are they a special case where this isn't required? Or maybe it's a magical property of hermetian operators? Or maybe it just works and I shouldn't think too hard about it.
1) it works
2) the second formula is not linear
3) There is probably some deeper reason why this works
If you start with the standard definition of the expectation value of a random variable <A> = Ʃi piai -where the ais are the possible outcomes and pi is the probability to obtain the i-th- your first formula follows from the QM postulates about these quantities. I don't know if this is satifying to you. ;-)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
