Show integral is equal to Bessel function
The discussion centers on proving the equality between a specific integral and the Bessel function J_0. The integral involves an exponential function and a variable y, with attempts made to simplify it through various substitutions. A participant suggests expanding the exponential term on the right-hand side into a double series, which leads to a series definition for J_0. However, the main challenge remains in demonstrating that the left-hand side of the equation equals the right-hand side. The conversation highlights the complexity of the proof and the need for further exploration of the integral's properties.
jackmell
Hi guys,
I'm pretty sure the following is true but I'm stuck proving it:
<br /> \begin{align*}<br /> \frac{1}{2\pi}\int_{-1}^1 \left(\frac{e^{\sqrt{1-y^2}}}{\sqrt{1-y^2}}+\frac{e^{-\sqrt{1-y^2}}}{\sqrt{1-y^2}}\right) e^{iyx} dy&amp;=\frac{1}{2\pi i}\mathop\oint\limits_{|t|=1} \exp\left\{\sqrt{x^2-1}(t-1/t)/2\right\}t^{-1}dt\\<br /> &amp;=J_0(\sqrt{x^2-1})<br /> \end{align*}<br />
I tried the substitutions:
y=i/2(t-1/t)
y=1/2(t-1/t)
y=i/2\sqrt{x^2-1}(t-1/t)
but not getting it. Also, I think only the first substitution converts the domain of integration into the required circle around the origin but that 's not too clear to me as well. Anyone can make a suggestion what to try next? Not sure if I should have posted this in the homework section.
Edit: Ok, I made a mistake in the Bessel integral notation. It's z/2 and not iz/2 so I changed it above and will re-do my calculations. May change things for me.
Thanks,
Jack
You can expand the exponential term on the rhs as a product of two series:
\exp\left(\frac{\sqrt{x^2-1}}{2}\left(t-\frac{1}{t}\right)\right)=\sum_{n=0}^{\infty}\frac{(\sqrt{x^2-1})^n}{2^nn!}t^n\sum_{k=0}^{\infty}\frac{(\sqrt{x^2-1})^k}{2^kk!}(-t)^{-k}
and so it becomes
\sum_{n=0}^{\infty}\sum_{k=0}^{\infty}\frac{(\sqrt{x^2-1})^{n+k}}{2^{n+k}n!k!}(-1)^k\frac{1}{2\pi i}\oint\frac{t^{n-k}}{t}dt
The contour integral is now 1 if n=k and 0 otherwise, giving the series
\sum_{n=0}^{\infty}\frac{(\sqrt{x^2-1})^{2n}}{2^{2n}n!n!}(-1)^n
which is the series definition for J_{0}\left(\sqrt{x^2-1}\right).
Ok, but that only shows how the RHS is equal to the Bessel function. I was wanting to figure out how to show the LHS is equal to the RHS.
