Show that if vv' = 0 (both vectors) then speed v is constant
The discussion revolves around demonstrating that if the dot product of a velocity vector \( v \) and its derivative \( v' \) equals zero, then the speed of the particle is constant. The context is within the study of motion and kinematics.
  • Participants explore the implications of the condition \( v \cdot v' = 0 \) and question how this relates to the constancy of speed. Some suggest considering cases where either vector is zero, while others discuss the relationship between kinetic energy and speed.
There is an active exploration of different interpretations of the problem. Some participants have offered guidance on how to approach the proof, while others have raised concerns about the validity of certain arguments. The discussion is ongoing, with various perspectives being considered.
Participants note that the problem may not require knowledge of kinetic energy, and there is a focus on the mathematical properties of the vectors involved. There are also reminders about the forum's rules regarding providing complete solutions.
Keshroom
Show that for a particle moving with velocity v(t), if v . v'=0
then the speed v is constant.
Let v = (v1,v2,...,vn)
and let v'= (v'1,v'2,...,v'n)
So,
v . v'= v1v'1 + v2v'2 + ... + vnv'n = 0
This is the only way i can think of to go about it but I'm stuck here. What do i do to show v is constant when v.v'=0?
So,
what do u mean by v' and v
Suppose you've got a particle with mass=1.
What would the derivative of its kinetic energy be?
since v dot v'=0 then you have to consider two cases
when v=the zero vector or when v'=the zero vector
dT/dt = mv.dv/dt
when m =1
dT/dt= v.dv/dt
i can simplify furthur, but why?
v' is the derivative of v ( velocity )
So, you know that T'=v.v'
Agreed?
either v=0 or v'=0. v=o means constant vel. and dv/dt=0 means vel. is not changing w.r.t. time. thus vel. is constt.
Agreed?
yep agreed
This is incorrectly argued.
You can perfectly well have non-constant vectors whose dot product is always equal to zero.
The critical issue is that when those two vectors are related as a function and its derivative, THEN, we may prove that the SPEED (not the velocity!), must be constant.
Keshroom said:
yep agreed
But, it then follows that since T'=0 in your case, then it must also be true that T=constant.
Agreed?
Furthermore, if T is constant, what can you say about whether the speed is constant or not?
Agreed?
ok, so if T' is zero, that means acceleration =0 so therefore the speed will be constant. right?
No.
If 1/2*v^2 =constant, (where v^2 is the dot product of the velocity by itself, equalling the squared speed), then it follows the speed must be constant.
Suppose that you move, with uniform speed along a circle.
Neither your velocity or accelerations are constants, but the acceleration vector is always orthogonal to the velocity vector.
the velocity vector in this case is tangential to the circle (changing all the time in its direction), while the acceleration vector is strictly centripetal (changing all the time in its direction). non-uniform speed along the circle would make the acceleration somewhat tangentially orientated as well, i.e, its dot product with the velocity would be..non-zero
alright i understand the theory behind it. But assume we didn't know anything about how this question is related to kinetic energy, how would i begin to solve it?
Since it was a question in my math class and you are not expected to know kinetic energy.
You don't need kinetic energy. There's nothing special about velocity here; I would take that v to mean any arbitrary vector quantity that satisfies [itex]\mathbf v \cdot \mathbf v ' = 0[/itex]. All you just need to do is to look at the derivative of the inner product of this vector v with itself.
Deleted sorry didn't read the rules:
Also, please DO NOT do someone's homework for them or post complete solutions to problems. Please give all the help you can, but DO NOT simply do the problem yourself and post the solution (at least not until the original poster has tried his/her very best).
This is not the correct approach. This approach (and arildno's) proves that if the speed is constant then v·v'=0. The problem at hand is the reverse problem, given that v·v'=0, show that speed must be constant.
To solve the problem at hand, it helps to first prove that the time derivative of a unit vector is either zero or is orthogonal to the unit vector.
blastoise said:
Case 2, there exists at lest one vn(t) that is not constant. Then v'n will not be zero at some t. Thus, (v1,v2,...,vn) dot (v'1,v'2,...,v'n) ≠ 0
Opinions?
My first opinion is that you should read our rules regarding solving people's homework for them.
My second opinion is that your proof is incorrect.
wasn't a proof but deleted it due to rules, but still would like a solution to this myself
At any point in time the velocity vector [itex]\vec v[/itex] can be expressed as the product of a scalar and some unit vector: [itex]\vec v = v \hat v[/itex]. Now use use the hint I gave in post #16.
  • · Replies 20 ·
  • · Replies 38 ·
  • · Replies 20 ·
