Showing Feynman-amplitudes' gauge invariance (for Compton Scattering)
58 replies · 8K views
JD_PM
Show that the Feynman amplitude for Compton scattering ##\mathcal{M} = \mathcal{M}_a + \mathcal{M}_b## is gauge invariant while the individual contributions ##\mathcal{M}_a## and ##\mathcal{M}_b## are not, by considering the gauge transformations
$$\varepsilon^{\mu} (\vec k_i) \rightarrow \varepsilon^{\mu} (\vec k_i) + \lambda k^{\mu}, \ \ \ \ \varepsilon^{\mu} (\vec k_f) \rightarrow \varepsilon^{\mu} (\vec k_f) + \lambda' k^{'\mu}$$
This is exercise 8.7 in Mandl & Shaw
Please see below
The Feynman amplitudes for Compton Scattering by electrons are (let us ignore helicity and polarization indices for simplicity)
\begin{equation*}
\mathcal{M}_a = -e^2 \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \varepsilon\!\!\!/ (\vec k_i) u(\vec p_i)
\end{equation*}
\begin{equation*}
\mathcal{M}_b = -e^2 \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_i) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \varepsilon\!\!\!/ (\vec k_f) u(\vec p_i)
\end{equation*}
Given the gauge transformations
$$\varepsilon\!\!\!/ (\vec k_i) \rightarrow \varepsilon\!\!\!/ (\vec k_i) + \lambda k\!\!\!/, \ \ \ \ \varepsilon\!\!\!/ (\vec k_f) \rightarrow \varepsilon\!\!\!/ (\vec k_f) + \lambda' k\!\!\!/'$$
We get
\begin{align*}
\mathcal{M}'_b &= -e^2 \bar u(\vec p_f) \left(\varepsilon\!\!\!/ (\vec k_i) + \lambda k\!\!\!/ \right) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \left(\varepsilon\!\!\!/ (\vec k_f) + \lambda' k\!\!\!/' \right) u(\vec p_i) \\
&= -e^2 \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_i) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \varepsilon\!\!\!/ (\vec k_f) u(\vec p_i) \\
&- \lambda \lambda' e^2 \bar u(\vec p_f) k\!\!\!/ \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) k\!\!\!/' u(\vec p_i) \\
&-\lambda' e^2 \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_i) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) k\!\!\!/' u(\vec p_i) \\
&-\lambda e^2 \bar u(\vec p_f) \lambda k\!\!\!/ \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \varepsilon\!\!\!/ (\vec k_f) u(\vec p_i) \\
\end{align*}
Analogously
\begin{align*}
\mathcal{M}'_a &= -e^2 \bar u(\vec p_f) \left(\varepsilon\!\!\!/ (\vec k_f) + \lambda' k\!\!\!/' \right) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \left(\varepsilon\!\!\!/ (\vec k_i) + \lambda k\!\!\!/ \right) u(\vec p_i) \\
&= -e^2 \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \varepsilon\!\!\!/ (\vec k_i) u(\vec p_i) \\
&- \lambda \lambda' e^2 \bar u(\vec p_f) k\!\!\!/' \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) k\!\!\!/ u(\vec p_i) \\
&-\lambda' e^2 \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) k\!\!\!/ u(\vec p_i) \\
&-\lambda' e^2 \bar u(\vec p_f) \lambda k\!\!\!/' \left( \frac{i}{p\!\!\!/ - m + i\varepsilon}\right) \varepsilon\!\!\!/ (\vec k_i) u(\vec p_i) \\
\end{align*}
OK. I am not sure if what follows is correct but there we go. Next we should use Ward's identity but I am not sure how to apply it in this problem. I thought of ##k\!\!\!/ =0## and ##k\!\!\!/' =0## but that is not correct, as it would imply that the individual Feynman amplitudes are invariant by themselves, which is stated to not be the case.
Any hint is appreciated.
Thank you :smile:
Hi @Gaussian97 I just wanted to ping you in case you missed it. If you do not have time I understand of course :smile:
Hello, well basically the Ward identity is what you want to prove here, so is not a good idea try to use it to prove what you want.
What I would do is, first of all, what is ##p##? Write ##p## as a function of the external 4-momenta. And then write the propagator with all the matrices in the numerator, otherwise, it will be impossible to manipulate it.
Alright. Let me change notation for the internal momenta: it will be labeled as ##q##. Energy-momentum conservation at each vertex implies ##q=p_i +k_i = p_f + k_f##, so we have
$$\mathcal{M}_a = -e^2 \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) iS_F \left(q=p_i +k_i = p_f + k_f \right) \varepsilon\!\!\!/ (\vec k_i) u(\vec p_i)$$
So I think you want to work with the following form of the fermion propagator (?)
$$S_F = \frac{q\!\!\!/ + mc}{p^2 -m^2c^2 + i \varepsilon}$$
Yes, but notice that the momentum ##p## or ##q## is different for both amplitudes.
Yes, assuming that ##p=q##.
Indeed. Let us explicitly work with ##\mathcal{M}_a## as an example; ##\mathcal{M}_b## should follow once I understand the procedure.
Oops typo.
OK so we have
$$\mathcal{M}_a = \frac{-ie^2}{
q^2 -m^2c^2 + i \varepsilon} \bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \left(q\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_i) u(\vec p_i)$$
Gaussian97 said:
... to manipulate it.
Once here, what kind of manipulations do you have in mind?
Well, there are two parts here, one, to prove that ##\mathscr{M}_a## and ##\mathscr{M}_b## are not invariant, and second to prove that ##\mathscr{M}_a+\mathscr{M}_b## is invariant.
I think the first ones are not really important, but proving something is not invariant is not trivial in general. I would simply choose arbitrary values for the momenta and spin, choose a representation for the Dirac matrices and compute the amplitude numerically, seeing that is really not invariant.
For the second part, proving that ##\mathscr{M}## is invariant, you cannot simply work with one of the amplitudes, since you'll need both together to make it invariant.
I recommend you to write the expression for ##\mathscr{M}## (without the gauge transformation for now) and try to simplify it.
OK, let's focus on showing that ##\mathcal{M}=\mathcal{M}_a+\mathcal{M}_b## is invariant.
We have
\begin{align*}
&\mathcal{M}=\mathcal{M}_a+\mathcal{M}_b \\
&- \frac{ie^2 \bar u(\vec p_f)}{q^2 -m^2c^2 + i \varepsilon} \left[ \varepsilon\!\!\!/ (\vec k_f) \left(q\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_i) + \varepsilon\!\!\!/ (\vec k_i) \left(q\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_f)\right] u(\vec p_i)
\end{align*}
We recall how the projector operators are defined
\begin{equation*}
\Lambda^{\pm} (\vec q) := \frac{\pm q\!\!\!/ + mc}{2 mc}
\end{equation*}
Thus we get
\begin{align*}
&- \frac{ie^2 \bar u(\vec p_f)}{q^2 -m^2c^2 + i \varepsilon} \left[ \varepsilon\!\!\!/ (\vec k_f) \left(q\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_i) + \varepsilon\!\!\!/ (\vec k_i) \left(q\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_f)\right] u(\vec p_i) \\
&= -ie^2\frac{\bar u(\vec p_f)}{q^2 -m^2c^2 + i \varepsilon}2mc \Lambda^+(\vec q) \left[ \varepsilon\!\!\!/ (\vec k_f) \varepsilon\!\!\!/ (\vec k_i) + \varepsilon\!\!\!/ (\vec k_i) \varepsilon\!\!\!/ (\vec k_f)\right] u(\vec p_i)
\end{align*}
I would say we should go for the gauge transformations at this point. But I am not sure how to deal with the product of the polarization states.
I've been reading a bit and found the following relation (Mandl & Shaw, page 135)
Is this the approach you were picturing in your mind?
JD_PM said:
We have
\begin{align*}
\end{align*}
No, this is not correct, that's why I told you to write ##q## in terms of the initial and final momenta. Not only because you'll need to know this relation to prove the invariance, but also because you are using the same letter for two different things, and this always leads you to mistakes.
Even if this were okay, you could still factor the photon polarizations, which will simplify the expression a lot when you do the transformation.
No, I don't think this is necessary. You are not summing over polarizations, the amplitude must be invariant for each polarization.
Absolutely, thanks for your patience 🤝
So we instead have
\begin{align*}
&- \frac{ie^2}{(p_i + k_i)^2 -m^2c^2 + i \varepsilon} \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \left(p_i\!\!\!/ + k_i\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_i)u(\vec p_i) \right] \\
&- \frac{ie^2}{(p_i - k_f)^2 -m^2c^2 + i \varepsilon} \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_i) \left(p_i\!\!\!/ - k_f\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_f)u(\vec p_i) \right] \\
&= - ie^2\frac{2mc}{(p_i + k_i)^2 -m^2c^2 + i \varepsilon} \Lambda^{+}(\vec p_i + \vec k_i) \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \varepsilon\!\!\!/ (\vec k_i)u(\vec p_i) \right]
&-ie^2\frac{2mc}{(p_i - k_f)^2 -m^2c^2 + i \varepsilon} \Lambda^{+}(\vec p_i - \vec k_f) \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_i) \varepsilon\!\!\!/ (\vec k_f)u(\vec p_i) \right]
\end{align*}
Should we proceed by applying the gauge transformations
##\varepsilon\!\!\!/ (\vec k_i) \rightarrow \varepsilon\!\!\!/ (\vec k_i) + \lambda k\!\!\!/, \ \ \ \ \varepsilon\!\!\!/ (\vec k_f) \rightarrow \varepsilon\!\!\!/ (\vec k_f) + \lambda' k\!\!\!/'##?
So we instead have
\begin{align*}
\end{align*}
Ok, now it's almost correct, the only thing you should care about is that ##\Lambda## is a matrix and therefore doesn't commute with other matrices.
Even then, you can still simplify it a little before doing the gauge transformation, first of all, you have common terms that you can factor out, this is especially useful for the polarizations. Second, the denominator of the propagators can be also simplified using ##k^2=0## and ##p^2=m^2##.
OK let me go slowly. We have
\begin{align*}
&- \frac{ie^2}{(p_i + k_f)^2 -m^2c^2 + i \varepsilon} \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \left(p_i\!\!\!/ + k_f\!\!\!/ + mc \right) \varepsilon\!\!\!/ (\vec k_i)u(\vec p_i) \right] \\
&= - ie^2\frac{2mc}{(p_i + k_i)^2 -m^2c^2 + i \varepsilon} \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \Lambda^{+}(\vec p_i + \vec k_i) \varepsilon\!\!\!/ (\vec k_i)u(\vec p_i) \right]
&-ie^2\frac{2mc}{(p_i - k_f)^2 -m^2c^2 + i \varepsilon} \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_i) \Lambda^{+}(\vec p_i - \vec k_f) \varepsilon\!\!\!/ (\vec k_f)u(\vec p_i) \right]
\end{align*}
Sorry this may be trivial for you but I want to see if I really understand it.
(i.e. why this is a physical process)
To do so, let us chose a particular Lorentz frame: the center of mass (COM) frame. For one of the vertices of ##\mathcal{M}_a## we have
$$p_i=(E_1=\sqrt{\vec p^2 + m_e^2}, \vec p)$$
$$k_i=(E_2=\sqrt{\vec k^2 + (m_p=0)^2}, \vec k)$$
Taking the square of ##k_i##
$$k_i^2 = k_i \cdot k_i = E_2^2 -\vec k \cdot \vec k = \vec k \cdot \vec k - \vec k \cdot \vec k = 0$$
So indeed this looks like a physical photon. Let us check the other vertex to be sure. We should of course get ##k_i^2 = 0## as well
$$p_f=(E_1=\sqrt{\vec p^2 + m_e^2}, -\vec p)$$
$$k_f=(E_2=\sqrt{\vec k^2 + (m_p=0)^2}, -\vec k)$$
Taking the square of ##k_f##
$$k_f^2 = k_f \cdot k_f= E_2^2 -\vec k \cdot \vec k = \vec k \cdot \vec k - \vec k \cdot \vec k = 0$$
We conclude that this photon is indeed physical.
On the COM frame, we indeed get
$$p^2 = p_i^2 = p_f^2 = E_2^2 - \vec p^2= \vec p^2 + m_e^2 - \vec p^2 = m_e^2$$
Note: I have switched to natural units.
Back to the original problem:
When you suggest to factor terms out of our result do you mean that we should be able to simplify the propagators so that they are the same and we get a term of the form (?)
$$\text{consts.} \times \text{propagator} \times u(\vec p_f)\left(\varepsilon\!\!\!/ (\vec k_f) \Lambda^{+}(\vec p_i + \vec k_i) \varepsilon\!\!\!/ (\vec k_i) + \varepsilon\!\!\!/ (\vec k_i) \Lambda^{+}(\vec p_i - \vec k_f) \varepsilon\!\!\!/ (\vec k_f) \right) u(\vec p_i)$$
I do not get the above structure. The most simplified form I could obtain is the following
\begin{align*}
&= - ie^2\frac{2m}{2 p_i \cdot k_i + i \varepsilon} \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_f) \Lambda^{+}(\vec p_i + \vec k_i) \varepsilon\!\!\!/ (\vec k_i)u(\vec p_i) \right]
&+ie^2\frac{2m}{2 p_i \cdot k_i - i \varepsilon} \left[\bar u(\vec p_f) \varepsilon\!\!\!/ (\vec k_i) \Lambda^{+}(\vec p_i - \vec k_f) \varepsilon\!\!\!/ (\vec k_f)u(\vec p_i) \right]
\end{align*}
Well, no, I wasn't talking about factoring the propagator, because they are clearly different. In fact in your expression
JD_PM said:
\begin{align*}
\end{align*}
The second term should have ##\frac{1}{p_i\cdot k_f}## instead of ##\frac{1}{p_i\cdot k_i}##.
But notice that there are lots of common things in both expressions, like the ##-2ime^2## or the ##u## spinnors and the polarizations ##\varepsilon##.
Typo, my bad.
Gaussian97 said:
... and the polarizations ##\varepsilon##.
But they are different: notice that the first term is left-multiplied by ##
\varepsilon\!\!\!/ (\vec k_f)## while the second one is left-multiplied by ##\varepsilon\!\!\!/ (\vec k_i)##. I think we cannot factor them out.
Yes, but in both terms you have both polarizations, the order is not a big deal, since the non-commutability is due to the fact that they are contracted with Dirac matrices, but the polarizations themselves are number and therefore commute, so we don't care in which order appear.
Ahhh I think I get it!
Based on
$$\varepsilon\!\!\!/ := \gamma^{\mu} \varepsilon_{\mu}$$
We get
\begin{align*}
&= - 2ime^2 \bar u(\vec p_f) \varepsilon_{\mu} (\vec k_f) \left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\nu} \right] \varepsilon_{\nu} (\vec k_i)u(\vec p_i)
\end{align*}
What about now? :smile:
Yeah, that's the idea. Just be careful because now, if you follow the contractions, ##\varepsilon_{\mu}(k_f)## is always on the left. Or, in other words, you could also factor out ##\gamma^\mu##, which is equivalent to factor the original ##\not{\!\varepsilon}(k_f)## which we already discussed is not possible.
After fixing that we can start doing the gauge transformations, but first of all the ones you give here are quite ambiguous
what is ##k## and ##k'##? And what is ##\lambda## and ##\lambda'##?
Absolutely, I think the way to fix it is to make ##\varepsilon## index independent! There is only one way I could think of to achieve that: introducing the Kronecker-delta distribution. I have been trying different ways to get it but it does not seem to work. Should I insist or this is not the right approach?
No, is much easier, you simply associate the index ##\mu## with ##\varepsilon(k_f)##, so in the first term, since ##\varepsilon(k_f)## was on the left, you write ##\gamma^\mu## on the left, but since in the other term was in the right you need to write ##\gamma^\mu## on the right. And the other way around for ##\gamma^\nu##.
So the correct expression is
$$\mathcal{M}= - 2ime^2 \bar u(\vec p_f) \varepsilon_{\mu} (\vec k_f) \left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\nu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\mu} \right] \varepsilon_{\nu} (\vec k_i)u(\vec p_i)$$
Take a moment to check that this is equivalent to what you had when we contract the indices.
💡##\times 2##
I would not say equivalent, as my expression (as you noticed) yielded ##\not{\!\varepsilon}(k_f)## to the left on both terms which is incorrect. So you are right and my equation #17 is wrong 🙂
Great, let's tackle gauge invariance. The transformations I provided are those presented by M&S themselves and I agree they are not clear. What I understand is that they really meant 4-vectors i.e. (we note that gamma matrices do not transform under gauge transformations so no necessity of including them)
$$\varepsilon^{\mu} (\vec k_i) \rightarrow \varepsilon^{\mu} (\vec k_i) + \partial^{\mu} f(k_i), \ \ \ \ \varepsilon^{\nu} (\vec k_f) \rightarrow \varepsilon^{\nu} (\vec k_f) + \partial^{\nu} g(k_f)$$
But what are ##f(k), g(k)##? Not clear, but based on page 134 we could guess that
$$f(k), g(k) \sim \exp(\pm ikx)$$
Let me provide you with more info
Besides, I have been reading M&S pages 134, 135
Ok, my question was essentially to see if you knew what they were or not. I see you don't have it very clear. The answer is that ##k## and ##k'## must be the 4-momenta of the photons, while ##\lambda## and ##\lambda'## can be any two real numbers.
Knowing that, we are ready to do the transformation of ##\mathscr{M}##.
Mmm but why we don't have the regular gauge transformation structure i.e.
You can look at section 8.3 of M&S, there you can see the reason, if you have doubts then we can discuss it here if you want.
If it is not clear after re-reading 8.3 I will indeed comment on it, thank you.
Good, let us assume it for now and proceed with the explicit computation of the gauge transformations.
Let's go slowly. We have
\begin{align*}
&\mathcal{M}'= - 2ime^2 \bar u(\vec p_f) \left( \varepsilon_{\mu} (\vec k_f) + \lambda' k_{\mu}'\right) \times \\
&\times \left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\nu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\mu} \right] \times \\
&\times \left( \varepsilon_{\nu} (\vec k_i) + \lambda k_{\nu}\right) u(\vec p_i) \\
&= - 2ime^2 \bar u(\vec p_f) \varepsilon_{\mu} (\vec k_f) \left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\nu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\mu} \right] \varepsilon_{\nu} (\vec k_i)u(\vec p_i) \\
&- 2\lambda \lambda' ime^2 \bar u(\vec p_f) k_{\mu}' \left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\nu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\mu} \right] k_{\nu} u(\vec p_i) \\
&- 2\lambda ime^2 \bar u(\vec p_f) \varepsilon_{\mu} (\vec k_f) \left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\nu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\mu} \right] k_{\nu} u(\vec p_i) \\
&- 2\lambda 'ime^2 \bar u(\vec p_f) k_{\mu}' \left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\nu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\mu} \right] \varepsilon_{\nu} (\vec k_i)u(\vec p_i) \\
\end{align*}
(typing...)
OK I think that the best at this point is to make a guess. We have
$$\mathcal{M}' \sim \mathcal{M} - k'_{\mu}\gamma^{\mu} \gamma^{\nu} k_{\nu} - k_{\nu}\gamma^{\nu} \gamma^{\mu} k_{\mu}'-\varepsilon_{\mu} \gamma^{\mu}k_{\nu}\gamma^{\nu} - k_{\nu}\gamma^{\nu}\varepsilon_{\mu} \gamma^{\mu}-k_{\mu}' \gamma^{\mu} \varepsilon_{\nu} \gamma^{\nu} - \varepsilon_{\nu} \gamma^{\nu} k_{\mu}' \gamma^{\mu}$$
Where we cannot add consecutive terms because each carries different propagators.
But how to deal with ##k_{\mu} \gamma^{\mu}## contractions? I have been trying to get the right structure and use
$$k^{\mu}\mathcal{M}_{\mu \nu}=0$$
But I got more confused... could you please give me a hint?
Well, it's true that they carry different propagators, but that doesn't mean we cannot combine them, we have split the amplitude into 4 terms, the first one is the original one, so our aim is to prove the other three terms to be zero. Let's analyse them case by case, I recommend you to start with the 3rd case. Let's forget about all the constants and polarization, the only relevant things here are the matrices (including ##u## and ##\bar{u}##) and the 4-momentum. We have something of the form
$$\bar u(\vec p_f)\left[ \gamma^{\mu} \frac{\Lambda^{+}(\vec p_i + \vec k_i)}{2p_i \cdot k_i + i \varepsilon}\gamma^{\nu} - \gamma^{\nu} \frac{\Lambda^{+}(\vec p_i - \vec k_f)}{2p_i \cdot k_f - i \varepsilon}\gamma^{\mu} \right] k_{\nu} u(\vec p_i) \\$$
Now, using Dirac equation and the properties of Dirac matrices, try to simplify these two terms:
$$\Lambda^+(\vec p_i + \vec k_i)\not{\!k}_iu(\vec p_i) = \cdots$$
$$\bar{u}(\vec p_f)\not{\!k}_i\Lambda^+(\vec p_i - \vec k_f) = \cdots$$
Alright so
Alright, you suggested to use the Dirac equation
$$(i\not{\!\partial} - m) \psi(x) = 0$$
As well as properties related to Dirac matrices. I guess those are (mostly related to ##\Lambda^+##; let me omit helicity and matrix indices)
$$\Lambda^+( \vec p) u (\vec p)= u (\vec p)$$
$$\bar u (\vec p) \Lambda^+( \vec p) =\bar u (\vec p)$$
$$\Lambda^+( \vec p) = u (\vec p)\bar u (\vec p)$$
Thinking how to use them (I think all I need is rest a bit and I will see it)
