Showing that Laplace's equation holds
Cole A.
(From Plonsey, R. and R. C. Barr, "Bioelectricity: A Quantitative Approach")
Show
[tex]\nabla^2 r = 0[/tex]
given
[tex]r = \sqrt{x^2 + y^2 + z^2}.[/tex]
[tex]\nabla = \frac{\partial}{\partial x}{\bf i} + \frac{\partial}{\partial y}{\bf j} + \frac{\partial}{\partial z}{\bf k}[/tex] (the "abuse of notation")
This is my first attempt at a post on this forum, and I'm embarrassed to say I'm really struggling with this question. (Not a homework problem per se, just an in-text side note). It has been a good while since I've studied vector calculus, so if somebody could point out my error, I would appreciate it.
Beginning with
[tex] \begin{equation}<br /> r = (x^2 + y^2 + z^2)^{1/2}<br /> \end{equation}[/tex]
taking the gradient results in
[tex] \begin{equation}<br /> \begin{aligned}<br /> \nabla r &= \frac{\partial r}{\partial x} {\bf i} + \frac{\partial r}{\partial y} {\bf j} + \frac{\partial r}{\partial z} {\bf k} \\<br /> &= \left[ \frac{x}{(x^2 + y^2 + z^2)^{1/2}} \right]{\bf i} + \left[ \frac{y}{(x^2 + y^2 + z^2)^{1/2}} \right]{\bf j} + \left[ \frac{z}{(x^2 + y^2 + z^2)^{1/2}} \right]{\bf k}.<br /> \end{aligned}<br /> \end{equation}[/tex]
Now taking the divergence of this gradient [itex]-[/itex] which amounts cumulatively to taking the Laplacian of [itex]r -[/itex] gives
[tex] \begin{equation}<br /> \begin{aligned}<br /> \nabla \cdot \nabla r &= \nabla^2 r \\<br /> &= \frac{\partial}{\partial x}\left[ \frac{x}{(x^2 + y^2 + z^2)^{1/2}} \right] + \frac{\partial}{\partial y}\left[ \frac{y}{(x^2 + y^2 + z^2)^{1/2}} \right] + \frac{\partial}{\partial z}\left[ \frac{z}{(x^2 + y^2 + z^2)^{1/2}} \right] \\<br /> &= \left[ \frac{1}{(x^2 + y^2 + z^2)^{1/2}} - \frac{x^2}{(x^2 + y^2 + z^2)^{3/2}} \right] + \left[ \frac{1}{(x^2 + y^2 + z^2)^{1/2}} - \frac{y^2}{(x^2 + y^2 + z^2)^{3/2}} \right] + \left[ \frac{1}{(x^2 + y^2 + z^2)^{1/2}} - \frac{z^2}{(x^2 + y^2 + z^2)^{3/2}} \right] \\<br /> &= \left[ \frac{y^2 + z^2}{(x^2 + y^2 + z^2)^{3/2}} \right] + \left[ \frac{x^2 + z^2}{(x^2 + y^2 + z^2)^{3/2}} \right] + \left[ \frac{x^2 + y^2}{(x^2 + y^2 + z^2)^{3/2}} \right] \\<br /> &= \frac{2}{(x^2 + y^2 + z^2)^{1/2}}<br /> \end{aligned}<br /> \end{equation}[/tex]
which is not zero, although I very much wish it was. (Sorry for the long-winded calculations.)
Very good job. You got the right answer. I think the problem is with the original question. The laplacian of r isn't zero. The laplacian of 1/r is zero. Are you sure that's not what it says??
Ugh, I was starting to suspect I was wasting time because of a typo in the book. I attached the relevant portion of the textbook page as an image, where the above equality is listed along with a couple other vector identities.
Thanks for the extra input (and sanity check).
  • Textbook page section 1.6 Vector Identities with explanatory paragraphs and equations (1.31) div(Phi A-bar) = A-bar dot grad Phi + Phi div A-bar, (1.32) grad(Phi Psi) = Phi grad Psi + Psi grad Phi, and (1.33) Laplacian of r = 0 where r = sqrt(x^2 + y^2 + z^2).
Thanks for the extra input.
It's a typo alright. Pretty bad one too. Jeez. I'm aghast. Shocked, really. That's pretty fundamental, you'd think they would have checked that.
