Signal to Noise Ratio Calculation in Decibels: How to Simplify with Decibels
The discussion focuses on calculating the Signal-to-Noise Ratio (SNR) in decibels for a given input signal of 5 dBmV and a noise level of 20 dBμV. The correct SNR calculation yields an input SNR of 45 dB, while the output SNR, considering a noise figure of 6 dB, is determined to be 39 dB. Participants clarify that the noise figure equation should be interpreted as F = SNRIn - SNROut, emphasizing the importance of subtracting decibel values rather than dividing them. The conversation also addresses common misconceptions regarding the conversion of decibels to voltage.
  • Understanding of decibel (dB) calculations and conversions
  • Familiarity with Signal-to-Noise Ratio (SNR) concepts
  • Knowledge of noise figure and its implications in signal processing
  • Basic principles of amplifier gain and input/output relationships
  • Study the relationship between voltage and decibels in signal processing
  • Learn about the implications of noise figure in amplifier design
  • Explore advanced SNR calculations in different contexts, such as RF systems
  • Investigate common pitfalls in decibel arithmetic and their resolutions
Electrical engineers, telecommunications professionals, and students studying signal processing or amplifier design will benefit from this discussion, particularly those focused on improving SNR calculations and understanding noise figures.
Jason-Li
(a) Determine the voltage required on the input of the amplifier to give
the maximum output of 85 dBμV.
(b) If the signal level from the aerial is 5 dBmV and the input noise level
is 20 dBμV, calculate the signal-to-noise ratio on the output of the
amplifier.
Values:
Bandwidth 40–862 MHz
Gain 20 dB
Noise Figure 6 dB
Max. Output 85 dBV
Input Impedance 75Ω
Output Impedance 75Ω
SNR=20Log(Vs/Vn)
SNR=10Log(Ps/Pn)
So pretty confident I understand part (a) however for part (b) I'm not sure if I have carried it out correctly if someone could give me a pointer?
(b)
5dBmV Input as a voltage:
5=20Log(V/1mV)
V=105/10
V=1.77827941mV
Then the noise level is 20dbμV so changing to a voltage:
20=20*Log(V/1μV)
V=1020/20
V=10μV
Then I can find the SNR of the input using:
SNRIn=20*Log(Vp/Vn)
SNRIn=20*Log((1.77827941*10-3)/(10*10-6))
SNRIn=45dB
Then as I have the Noise figure from the data as F=6dB I can do the following:
F=SNRIn/SNROut
SNROut=SNRIn/F
SNROut=45*6
SNROut=270dB
This seems far too high? I have found websites that say the formula is actually F = SNRIn-SNROut however the learning materials say:
I think you are correct as far as part (b). Then you know the SNR at the input, and the SNR at the output will be 6dB worse. So SNRout = 45 - 6 = 39dB.
Hi thanks for the reply and assurance, do you have any idea why my learning materials is citing the noise figure equation incorrectly?
Yes, the formula for F is not stated in decibels. To divide decibel quantities we subtract, not divide.
Jason-Li said:
Homework Statement:: (a) Determine the voltage required on the input of the amplifier to give
amplifier.
Values:
Gain 20 dB
Noise Figure 6 dB
Max. Output 85 dBV
Input Impedance 75Ω
Relevant Equations:: SNR=20Log(Vs/Vn)
SNR=10Log(Ps/Pn)
(b)
5=20Log(V/1mV)
V=105/10
V=1.77827941mV
20=20*Log(V/1μV)
V=1020/20
V=10μV
SNRIn=20*Log(Vp/Vn)
SNRIn=45dB
F=SNRIn/SNROut
SNROut=SNRIn/F
SNROut=45*6
SNROut=270dB
Hi, I am struggling with part A to this question, could you assist? I am not sure where to start.
In Part (a) the output of the amplifier is 85 dBuV and the gain of the amplifier is 20 dB. How many dBuV aat the input?
Do I need to convert dB into Voltage for both gain and Vo and then just use a transposed ratio for gain to calculate Vi?
No you can stay in dB entirely. Do not over think this one!
With gain just being a ratio, is it as simple as G = output / input... transformed giving 85 / 20 = Vi (however needing to subtract rather than divide) 85 - 20 = Vi?
When we multiply or divide quantities using decibels we simply add or subtract. So for instance, if I have a signal of 10 dBV and I amplify it by 6 dB I end up with a signal of 10 + 6 = 16 dBV.
The whole point of decibels is to make gains and losses simple to work out without the need to carry out multiplication or division.
It is only if voltages or powers are actually added or subtracted that we have to come out of the decibel system.
  • · Replies 23 ·
