Simple Analysis Question: Showing a Set is Closed
The discussion revolves around proving that the set A = {d(x, y) : y ∈ S} is closed, given that S is a nonempty closed subset of \mathbb{R}^n. A continuous function f is defined from S to ℝ, where f(y) = d(x, y), and the participants explore the sequence definition of closed sets. They establish that if a convergent sequence (p_n) in A converges to p, then it must be shown that p is also in A. The conversation highlights the use of the closedness of S and the completeness of S to demonstrate that the sequence of points y_n converges to a point in S, ultimately confirming that A is closed. The discussion effectively clarifies the necessary steps to complete the proof.
tylerc1991
Suppose S is a nonempty closed subset of \mathbb{R}^n, and let x \in \mathbb{R}^n be fixed. Show that A = \{d(x, y) : y \in S\} is closed.
A set is closed if its complement is open, or if it contains all of its limit points.
I first defined a function f : S \to \mathbb{R} by f(y) = d(x, y). Notice that f is continuous. Then A is not open because S is closed (if A is open then f^{-1}(A) is open). However, this doesn't show that A is closed.
I feel like I have the intuition, but actually showing this is frustrating. Help would be greatly appreciated!
So, what definition/characterization of closed would you like to use?? I like the sequence definition, do you know that one?
I think so. That definition states that the limit of a convergent sequence is contained in A if and only if A is closed. So to show that A is closed, I would start with an arbitrary convergent sequence of points of A, say (p_n) \to p \in \mathbb{R}, where (p_n) \subset A. I then need to show that p \in A. I am probably going to use the closedness of S in this right?
Yes. So take a convergent sequence (x_n)_n in A. We know that we can write x_n=d(x,y_n) for some y_n\in S. Can you show that the (y_n)_n is Cauchy?
How about this: Since (d(x, y_n)) is convergent, for all \varepsilon > 0, there exists an N > 0 such that
d(x, y_n) < \frac{\varepsilon}{2}
when n > N. Therefore, when m, n > N, we have
d(y_n, y_m) \leq d(y_n, x) + d(x, y_m) < \frac{\varepsilon}{2} + \frac{\varepsilon}{2} = \varepsilon,
which shows that (y_n) is Cauchy. Since S is complete, we have that (y_n) converges to a point of S. Then since f is continuous, (x_n) converges to a point of A?
Right. That's ok, I think.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
