Simple Calculus Questions Having to Do With Inverses
  • Thread starter Thread starter jsewell94
    Calculus
jsewell94
Suppose f^{-1}(x) is the inverse function of a differentiable function f Let G(x) = \frac{1}{f^{-1}(x)} If f(3) = 2 and f'(3) = 1/9 , find G'(2).
2. Stuff to know..
(f^{-1}(x))' = \frac{1}{f'(f^{-1}(x))}
http://i.imgur.com/X5Q9A.jpg?1?7662
I just have no idea if I'm doing this right or not..or if I've made a stupid calculation error. Thanks for the help!
Please show an attempt or this will be deleted.
jsewell94 said:
2. Stuff to know..
(f-1)'(x) = 1/f(f-1(x))
What you posted here makes no sense. Use Latex to format these expressions so they're more legible.
Okay, sorry about the sucky post. I was in a rush to get it up, and I didn't realize the image was screwed up. I also didn't take the time to format it neatly. Hope this is more readable. :)
Yes that makes sense now. I see that you also fixed one or more typos.
Your method & answer look correct.
BTW: You may be warned about an overly large image by one of the moderators.
Yes, it looks good.
But can you assume (f^{-1})'(x) = \frac{1}{f'(f^{-1}(x))} without proof?
Curious3141 said:
Yes, it looks good.
Yeah, you can assume this. We went over it in class, and I managed to prove it (maybe?).
According to the chain rule
(f(g(x))' = f'(g(x))g'(x)
So, consider: f(f^{-1}(x)) = x
According to the chain rule,f'(f^{-1}(x))(f^{-1})'(x) = 1
So, (f^{-1})'(x) = \frac{1}{f'(f^{-1})}
You can prove it if you want. Assuming an inverse exists, then y = f(x) which implies x = f-1(y) = f(f-1(x)) = f-1(f(x)) (by the properties of the inverse). Now can you differentiate these with respect to x using the differentiability rules to get it in the form of the above?
A kind-of-obvious point for the OP: you may want to also address the issue of the
possibility of your denominator being zero when you answer your question.
