Engineering Simple Diode Circuit Analysis: Homework Help and Solutions
The discussion focuses on analyzing a diode circuit to sketch the output voltage (vout) with a diode ON voltage of 0.6V. The key confusion arises from understanding the role of voltage sources after the diodes and how they affect current flow, particularly with an AC voltage source. It is clarified that the diodes will conduct when the anode voltage exceeds the cathode voltage by 0.6V, impacting the output voltage. The circuit is identified as a clipping circuit, oscillating between +5.6V and -8.6V. The participant expresses gratitude for the assistance in recognizing the circuit's behavior.
jmckennon
Attached is the homework problem I'm having difficulty with. I need to sketch vout for the circuit, assuming the diode ON voltage is 0.6 V. I'm stuck at how to begin this problem.
It's only the 2nd week of class so I'm not too good with this, and I'm a bit rusty with my circuits as it is. My initial idea was to find the current going in the circuit but I'm just absolutely confused by this question. I don't understand why there are voltage sources after the diodes and what that does to the circuit. I also get confused with how I should find the current with an AC voltage source. Any guidance in the correct direction would be greatly appreciated.
The diodes will conduct when the voltage at their anodes is 0.6V above the voltage at their cathodes.
While neither diode is conducting, there is no current, so, no voltage drop at the resistor.
Okay, that makes sense. What do the DC voltage sources after the cathodes do to the circuit?
They assure that the diodes will fire only when the AC source voltage is 0.6V over or below the voltages of the DC sources.
Depending on what Vin is, each diode can act like either a 0.6V voltage source or like an open circuit (i=0).
For example, if the left-hand diode is at 0.6V, that would add to the battery there to give Vout=____?
I actually figured out that the circuit was a clipping circuit. The sketch will oscillate between +5.6V and -8.6V. For some reason I wasn't able to recognize the circuit! Thanks for all the help!
  • · Replies 20 ·
