Simple Dynamics question (just help to check the answer)
  • Thread starter Thread starter dawn_pingpong
    Dynamics
The discussion revolves around a dynamics problem involving a 6.0 kg body dropped from a height of 7.5 m into a lake. The user calculates the speed just before entering the lake as 12.131 m/s and initially finds the acceleration in the lake to be -7.3333 m/s², but later realizes this is incorrect. The correct acceleration is determined to be -11.99 m/s², leading to a reevaluation of the subsequent calculations. The user expresses uncertainty about their approach and seeks confirmation on their solution. The thread highlights the importance of careful analysis in physics problems, especially regarding forces and acceleration.
dawn_pingpong
Okay I have done it, but have a feeling that there's something wrong. I don't have the solution/answer so it will be great if someone can help me check. more of part 2 (which leads to part 3)
a body of mass 6.0kg and density 450kg/m^3 is dropped from rest at a height of 7.5m into a lake. Calculate
1. the speed of the body just before entering the lake
2. the acceleration of body while its in the lake
3. the maximum depth to which the body sinks before returning to surface.
Neglect any surface tension or air resistance.
s=0.5gt2
sub s=7.5m, g=9.81, t=1.2365s
then v=gt, v=12.131m/s
2. Ffloat= ρgV, net force= Ffloat-mg
V=6.0/450=1/75, net force=-(1000 x 9.81 x 1/75 -6.0 x 9.81)=-71.94
then F=ma, a=-71.94/9.81=-7.3333m/s2
for me, down is positive, up is negative
3. using v2=v02+2as, v=0 when the body stops sinking.
s=10.034m, which is the distance sank.
Gahh I really think this question is rather easy, have not done dynamics for sometime, have given everything back to the teacher, sadly:(
Why is this?
ahh, it's you again:)
Oh shoot wrong wrong it's a=F/m=-71.94/6.0=-11.99, so everything else follows is wrong. Thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
