Simple elastic particle problem
  • Thread starter Thread starter seanistic
    Elastic Particle
The problem involves a 61.9kg object colliding elastically with a 44.9kg object, both moving in the same direction. The key to solving the problem lies in applying the conservation of momentum and the conservation of kinetic energy, as both are preserved in elastic collisions. The first object’s final velocity is unknown, complicating the use of momentum equations. To find the final velocities of both objects, set up equations for both momentum and kinetic energy. This approach will yield the necessary values for the second object's velocity after the collision.
seanistic
A 61.9kg object moving to the right at 43.3 cm/s overtakes and collides elastically with a second 44.9kg object moving in the same direction at 26.9cm/s
Find the velocity of the second object after the collision.
My homework says its in the chapter and section with "velocity of the center of mass" and "momentum in terms of velocity of CM" But I think its wrong and I should be looking at the elastic collision chapter.
I tried doing conservation of momentum but I don't know the velocity of object 1 after collision.
I tried using the elastic collision equations but those use one mass having a velocity of 0.
I pretty much confused where to start.
Use the conservation of linear momentum with the two unknown final velocities.
and then remember that in an elastic collision, kinetic energy is conserved and you can now find the two values for the final velocities.
