Simple harmonic motion equations as a function of time
The discussion revolves around the equations of simple harmonic motion (SHM) as functions of time, particularly focusing on how the stiffness of a spring and mass affect the frequency of oscillation. Participants explore different formulations for displacement, velocity, and acceleration, and the implications of initial conditions on these equations.
  • One participant presents equations for displacement, velocity, and acceleration in SHM, noting discrepancies with other sources that use sine instead of cosine.
  • Another participant suggests that the choice of formula depends on initial conditions, specifically the displacement and velocity at time t = 0.
  • A different participant introduces a general form of the SHM equation, including amplitude and phase, and explains how different initial conditions can lead to different forms of the equations.
  • Further discussion emphasizes the importance of determining the correct amplitude and phase based on experimental data, acknowledging potential errors in initial conditions.
  • One participant proposes using the cosine function for displacement based on specific initial conditions, while also providing a more general equation that incorporates both position and velocity at t = 0.
  • A scenario involving a body suspended from a spring is introduced, prompting questions about how to apply the SHM equations in this context, particularly regarding the measurement from the position of static equilibrium.
  • Participants discuss the need to compute angular frequency and solve a system of equations to determine the amplitude and phase for the specific scenario presented.
Participants express differing views on the appropriate equations to use based on initial conditions, with no consensus reached on a single correct formulation. The discussion remains unresolved regarding the best approach for specific scenarios involving SHM.
Participants note the dependence of the equations on initial conditions, which may vary based on experimental setup. There is acknowledgment of potential errors in determining these conditions, and the discussion highlights the need for careful consideration of definitions and assumptions in applying the equations.
zilex191
I conducted a mass-sprig experiment to see how stiffness of a spring and mass affect the frequency of oscillation. In addition to this to this i have to plot a graph to show displacement,velocity and acceleration of the mass as a function of time.From my research online
For the displacement as a function of time:
x(t)=x*cos(w*t)
For the velocity as a function of time(Deriving the above):
v(t)=x*w*sin(w*t)
For the acceleration as a function of time(Deriving the above):
a(t)=-x*w^2*cos(w*t)
But when i loot at other sources it shows different equations (such as instead of cos its sin).
x(t)=x*sin(w*t)
v(t)=x*w*cos(w*t)
a(t)=-x*w^2*sin(w*t)
My question is what formula do i use ?
The formula that you use depends on what you are trying to describe, namely what is the displacement of the mass at t = 0 and what is its velocity. These are the so-called initial conditions.
You need to use, for position
$$x(t) = A \cos{(\omega t + \varphi)}$$
where ##A>0## is called the "amplitude" and tells you the maximum distance to the equilibrium, ##\omega## is the "angular frequency" and tells you how many oscillations you do in ##2\pi## seconds and ##\varphi\in [0,2\pi)## is called "initial phase" and essentially gives you the information on what is the initial position and initial velocity.
Differentiating you get:
$$v(t) = -A\omega \sin{(\omega t + \varphi)}, \qquad a(t) = -A\omega^2 \cos{(\omega t + \varphi)}$$
Note that your first set of equations is putting ##\varphi=0##, and the second one is putting ##\varphi=\frac{3\pi}{2}##.
Displacement at of the mass at t=0 is the maximum displacement which is 0.05 meters
Then you must use (see my previous post)
##A=0.05 \text{m}##
##\phi = 0##
Although I would recommend you to try to figure out the values of ##A## and ##\phi## with your data because there are always some errors in setting the initial conditions.
Then the expression to use is ##x(t)=0.05~(\mathrm{m})\cos(\omega t)##. How do I know? Because at ##t=0## the expression gives ##x(0)=0.05~(\mathrm{m})\cos(0)=0.05~\mathrm{m}.##
More generally, if the mass at ##t=0## is at ##x(0)=x_0## and has velocity ##v(0)=v_0##, the position at any time ##t## is given by ##x(t)=x_0\cos(\omega t)+\dfrac{v_0}{\omega}\sin(\omega t)##. Note that the expressions provided by @Gaussian97 in #3 are also correct but, in my opinion, less transparent in the general case.
Thank you very much for your replies@kuruman @Gaussian97.
But in this case
Consider a body weighing 100 N suspended from a spring of constant k = 220 . At time t = 0, it has a downward velocity of 0.5 m.s-1 as it passes through the position of static equilibrium.
So i would use x(t)=Acos(ωt+φ) to work out the displacement x as a function of time, where x is measured from the position of static equilibrium?
But in this case
Yes, with ##k## and ##m## you can compute ##\omega##, then you need to solve the system of equations
$$0 = A \cos{(\varphi)}$$
$$-0.5\text{ms}^{-1} = -A\omega \sin{(\varphi)}$$
But in this case
Note that I edited my previous post and gave you a general equation to describe your situation. It might be instructive to do it the way that @Gaussian97 suggests and then redo it the way I suggest.
  • · Replies 21 ·
  • · Replies 36 ·
  • · Replies 17 ·
