Simple Harmonic Motion: Fire Net Stretch Calculations
The problem involves a scenario of simple harmonic motion where a person jumps onto a fire net, which behaves like a spring. The discussion focuses on calculating the net's stretch under different conditions: when the person is lying in the net and when jumping from varying heights.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of conservation of energy and the energy stored in a spring to determine the net's stretch. Questions arise regarding the correct interpretation of gravitational potential energy and how to account for the net's stretch in calculations.
Some participants have offered hints about using conservation of energy and the formula for elastic potential energy. There is an ongoing exploration of how to correctly set up the equations, particularly regarding the height from which the person falls and the resulting stretch of the net. Multiple interpretations of the problem are being considered.
Participants express uncertainty about the initial conditions and the assumptions regarding the net's behavior under different scenarios. There are indications of gaps in understanding the physics concepts involved, particularly in relating force, energy, and displacement.
FearTheHump
Simple harmonic motion! :(
A 65-kg person jumps from a window to a fire net 18m below, which stretches the net 1.1m. Assume that the net behaves like a simple spring, and (a) calculate how much it would stretch if the same person were lying in it. (b) How much would it stretch if the person jumped from 35m?
No idea. All of the equations I have seem to reference acceleration, or velocity, or force...etc. I can't figure out what to use for this.
I have no idea where to start with this question. What confuses me the most is the whole "falling 18 metres" or..."falling 35 metres". Now, I have got massive holes in my physics knowledge (slacked off a lot last year, I will admit), but from what I understand, f=ma, which means that the resulting force will be the same for both drops, right? Well, logically, no, but from my limited physics knowledge, apparently.
Please help me not fail physics once again! :(
Presumably they want the maximum stretch of the net. Hint: Use conservation of energy. What's the formula for calculating the energy stored in a stretched spring?
EPE = 1/2kx^2 right?
So for the 18m situation where i know x, would I use that to find k, then sub that into get x in the first question?
That would make sense to me, but usually things that make sense to me in Physics are wrong.
But anyway...
GPE(o) = KE (which is zero) + EPE(f)
mgh = 1/2kx^2
65 X 9.8 X 18 = 1/2 X k X 1.21
11466 = 0.605k
k = 18,952?
a) Still...no idea?
b) GPE(o) = KE (zero again) + EPE(f)
mgh = 1/2kx^2
65x9.8x35 = 1/2 X 18952 X x^2
22925 = 9476x^2
x = (square root of)2.42m
= 1.56m
This sounds about right, but I still have my doubts.PS - I've used capital X for multiplication, and lower case x for the variable.
Right.
But anyway...
mgh = 1/2kx^2
11466 = 0.605k
k = 18,952?
Almost right. Hint: Measure gravitational PE from the lowest point. (The person doesn't just fall 18 m, but 18 + x.)
a) Still...no idea?
Once you've got k, use Hooke's law.
mgh = 1/2kx^2
22925 = 9476x
x = 2.42m
You'll need to redo this, with the same caveat as above. (And careful with x^2 versus x.)
Thanks, but...how am I to know how much to add to the height in (b)?
Since the person drops from a higher position, it will be a larger number, right? I don't know what that number is, though, because that's what the whole equation is trying to solve.
Exactly. Since you don't know the amount that the net stretches in (b), call the unknown stretch x, set up your equations, and solve for it.
Ahhhh, a quadratic. Thanks! :D
  • · Replies 51 ·
  • · Replies 17 ·
