Simple Harmonic Motion homework
3 replies · 10K views
mike1467
I came across a physics problem for homework that I was able to work out on my own, however when I got to class, my teacher said that my numbers were not what the book had calculated, but couldn't tell if there was a flaw in my logic that would prevent me from getting the correct phi and therefore the correct answers.
The question:
A simple harmonic oscillator consists of a block of mass 4.20 kg attached to a spring of spring constant 200 N/m. When t = 4.00 s, the position and velocity of the block are x = 0.129 m and v = 3.415 m/s.
My approach
a.) What is the amplitude of the oscillations?
I used conservation of mechanical energy to solve this part of the problem, and got the correct amplitude this way:
(1/2)kx^2 + (1/2)mv^2 = (1/2)k(amplitude)^2
amplitude = .5114 m
b.) What was the position of the mass at t = 0 s?
For this part, I plugged the position I was given and the time I was given as well as the amplitude and omega, which I solved for, into this formula:
x(t) = amplitude * cos(omega * t + phi)
I solved for omega:
omega = (k/m)^(1/2)
omega = 6.9 rad/s
and used the amplitude from part a) and the given x and t to solve for phi
.129 = .5114 * cos(6.9 * 4 + phi)
.252 = cos(27.6 + phi)
1.316 = 27.6 + phi
phi = -26.28 rad
then I use this phi in the x(t) function to solve for x at t = 0:
x(0) = .5114 * cos(-26.28)
x(0) = .21 m
c.) What was the velocity of the mass at t = 0 s?
I use the same phi, amp, and omega from before, except in the equation:
v(t) = -omega * amplitude * sin(omega * t + phi)
v(0) = -(6.9) * (.5114) * sin(-26.28)
v(0) = 3.217 m/s
When my teacher does the problem another way, however, he got a phi that was different from mine.
Teacher's Approach
v(4)/x(4) = [-omega * amplitude * sin(omega * t + phi)] / [amplitude * cos(omega * t + phi)]
v(4)/x(4) = -omega * tan(omega * t + phi)
26.473 = -6.9 * tan(6.9 * 4 + phi)
-3.837 = tan(27.6 + phi)
-1.316 = 27.6 + phi
phi = -28.916 rad
He then proceeded to solve for the amplitude using x(t) = amplitude * cos(omega * t + phi) and x(0) and v(0) in pretty much the same way that I did.
My question is, why did using his method get the equation:
-1.316 = 27.6 + phi
phi = -28.916 rad
when my way instead gave me:
1.316 = 27.6 + phi
phi = -26.28 rad
In order to get the phi that my teacher got, I would have to alter the formula that I used to solve for phi to:
x(t) = amplitude * cos(-omega * t - phi)
which I don't think is correct. I would greatly appreciate any insight into this matter.
very nice post. What I think happened, is in your soln, amplitude could be
+/-.5114.
Assume you chose the negative root,
then -.252=cos(27.6+phi) which is same as since cos(pi-x)=-cos(x)
hence .252=cos(pi-27.6-phi)
Thanks for the clarification denverdoc, I guess neither me nor my teacher realized that by taking the sqrt we had a +/- .5114. For my approach, and not knowing the answer that my teacher got, is there any other way to tell that I should have used the negative amplitude instead of the positive one?
maybe a wave guru can help out, technically speaking the teachers approach was the more rigorous approach since it used d(y(t)/y(t) along with a snap shot of conditions at t=4, but yours would have worked as well just from knowing the argument is usually given as wt+/-phi, and then testing the soln to make sure of the sign. Overall I think you get an A+ for creative approach. Again, very nice job.
