Simple Harmonic Motion & Pendulum Problem
The discussion focuses on determining the correct length of a pendulum to ensure accurate timekeeping, given that a 0.5m pendulum clock is 30 minutes slow after 12 hours. Participants explore the relationship between the pendulum's frequency and the clock's timekeeping, debating whether to set the frequency to 1 Hz or 0.5 Hz. The correct approach involves calculating the necessary adjustments to the pendulum's period, leading to a derived length of approximately 0.453m. The conversation highlights the complexity of the mechanical system driving the clock and emphasizes the importance of precise calculations in achieving accurate time. Ultimately, the method for finding the correct length is clarified through the relationship between the time period and the pendulum's length.
Potatochip911
What length must the pendulum be changed to in order to show the correct time?
L=0.5m
After 12hours the clock is behind by 30minutes.
w=sqrt(g/L)
w=2πf
I thought if I set the frequency equal to 1Hz and solved for length it would work.
2πf=sqrt(g/L)
4π^2=g/L <-got rid of f since its equal to 1
L=g/(4π^2)
This unfortunately doesn't give the correct answer, I also tried making a ratio involving the time but that failed miserably.
L=0.5m
w=sqrt(g/L)
w=2πf
Why should be the frequency of the pendulum 1 Hz?
I thought that if frequency is 1Hz then it would be doing one cycle per second which would result in 1 tick of the clock per second but since its for the entire cycle and each cycle contains 2 ticks? So I should set frequency to 0.5Hz?
The swing of the pendulum drives the hands of the clock through some rather complicated mechanical system, including cogwheels. http://visual.merriam-webster.com/s...easure-time/weight-driven-clock-mechanism.php. The time period of the bob is proportional to the period of the hands of the clock, but is not equal to it. In case of a 0.5 m pendulum, the time period is 1.41 s. But the transmission system makes the clock going too slow - by what percent? By what percent have you change the time period of the pendulum, and what does it mean on the length?
tclock=41 400s
t=43 200s
tclock/t=23/24
The clock is going (1/24)% slower than the actual time, to fix this I should multiply the period by (23/24)?
T=1.41*(23/24)≈1.351
Then w=sqrt(g/L) ->w=2pi/T
(2pi/T)^2=g/L
L=g/(2pi/T)^2=0.453m
Thanks!
Potatochip911 said:
tclock=41 400s
t=43 200s
tclock/t=23/24
(2pi/T)^2=g/L
Thanks!
The method is correct, but you but you made it very complicated, and rounded off too early.
You know that Tcorrect/T = 23/24. Tcorrect/T = sqrt(Lcorrect/0.5). How do you get the correct length from here?
Yea that is definitely an easier way to solve for Lcorrect but I'm curious as to how you found this relationship between the period and length.
\frac{T_a}{T_b}=\frac{2\pi\sqrt{L_a/g}}{2\pi\sqrt{L_b/g}}=\sqrt{\frac{L_a}{L_b}}
You know how the formula ##ω=\sqrt{\frac{g}{L}}## was derived and you know the relation between angular frequency and time period: ##\omega=\frac{2\pi}{T}##.
So ##\frac {2\pi}{T}=\sqrt{\frac{g}{L}}##,
isolate T:
##{T}=2\pi\sqrt{\frac{L}{g}}##
