Physics Homework: Calculating the Area of a Large Square with a Circle Inside
The discussion centers on calculating the area of a large square containing a circle with an area of 47.4 cm². Participants utilized the formula for the area of a circle, A = πr², and derived the diameter using the distance formula, D = sqrt(x² + y²). The final area of the square was determined to be approximately 195.539 cm² after solving for the variable 'a' and substituting it into the area formula, 81a². The calculations confirmed the correct relationship between the circle's area and the square's dimensions.
  • Understanding of geometric formulas, specifically area calculations for circles and squares.
  • Familiarity with the distance formula in coordinate geometry.
  • Basic algebra skills for solving equations involving variables.
  • Knowledge of π (pi) and its application in area calculations.
  • Study the derivation of the area formulas for circles and squares.
  • Learn how to apply the distance formula in various geometric contexts.
  • Explore more complex geometric problems involving multiple shapes.
  • Practice solving equations with variables in real-world applications.
Students in geometry, educators teaching mathematical concepts, and anyone interested in solving geometric problems involving circles and squares.
BraindeadX64
The circle inside the large square below has an area of 47.4 cm2.
[URL]http://tinyurl.com/PhysicsSquare[/URL]
Calculate the area of the large square. Note that the circle passes right through a number of grid intersection points.Heres the help the professor gave
[URL]http://tinyurl.com/PhysicsSquare2[/URL]
C^2 = A^2 + B^2
D= sqrt(x^2 + b^2)
D = 2sqrt(A/pi)
4a tall and 1a long
1st attempt.
d = sqrt((1a)^2 + (4a)^2)
d = sqrt(1a + 16a)
d= sqrt(17a)
2nd attempt
d=2sqrt(47.4/pi)
d= 7.77
stuck here I am not sure what else to do
any help would be greatly appreciated!
What is D?
cupid.callin said:
What is D?
distance formula for diameter
well i haven/t checked your eqn but from the 2 results you got,,, equate them
you get 17a = 7.772
find a
now you know that area of large Square is 81a2
substitute a
you get 17a = 7.772
find a
substitute a
well those answers i got were different numbers for radius and it doesn't make any sense to me
the diameter is sqrt(17a), i just can't figure out how to get a by itself so i can do 81 * a^2 for the area of the grid
figured it out
a = 7.77cm / (sqrt (17) = 1.88cm
Area of the box = (9a*9a) =81a^2 =81*(1.88)^2 = 286.3 cm^2
BraindeadX64 said:
figured it out
Uh, no.
Area of a circle is A = \pi r^2[/tex] and r = D/2 so, A = \pi D^2/4[/tex]<br /> <br /> but D^2 = x^2 + y^2 = (4a)^2 + (3a)^2 = 16a^2 + 9a^2 = 25a^2[/tex], therefore<br /> <br /> A = \frac{25a^2 \pi}{4} = 47.4 ~ cm^2<br /> <br /> Simplifying, we get<br /> <br /> a^2 = \frac{4 (47.4 ~ cm^2)}{25 \pi} = \frac{189.6 ~ cm^2}{25 \pi} = \frac{7.584}{\pi} ~ cm^2<br /> <br /> Area of the square is then<br /> <br /> 81a^2 = 81 \cdot \frac{7.584}{\pi} ~ cm^2 = \frac{614.304}{\pi} ~ cm^2 \approx 195.539 ~ cm^2
zgozvrm said:
Uh, no.
<br /> <br /> those numbers are for the example not the circle at the top, my online submittion says it was right soo yeah.
My bad!
I didn't notice the circles were different and focused on the second one.
Your answer is correct.
