I How Does Shankar Transition from Sums to Integrals in Feynman Path Integrals?
  • I
  • Thread starter Thread starter Opus_723
    Feynman Integral
Opus_723
I am going through Shankar's treatment of Feynman Integrals right now, and I have one lingering doubt that I can't quite seem to work out.
I was pretty happy with the idea of discretizing time, then doing independent sums over xi at each time. But Shankar simply says that we can consider the sums over xi to be integrals. I don't quite follow this. Normally when you pass from a sum to an integral there has to be some infinitesimal factor in each term of your sum. Shankar just says that the sum over the phase factors becomes an integral in xi over the phase factors, but I don't see where the "dx" comes from in order to let us do that. I have a suspicion that something deeper is going on, but I can't quite grasp it.
I've actually noticed this sort of thing in a couple of other places. For example, the completeness relation for operators with discrete spectra seems to pick up an infinitesimal "d_" that doesn't seem to have a counterpart in the completeness relation for operators with discrete spectra. This may be completely unrelated to the path integrals. But I get the feeling that I'm missing something either very obvious or very subtle, because this sort of thing keeps coming up in QM. Could anyone help me clear this up?
In short, this is because the orthonormality of basis vectors is like ##\left<\psi_i \right.\left|\psi_j \right.\left.\right> = \delta_{ij}## in the discrete case and ##\left<x \right.\left|x' \right.\left.\right> = \delta (x-x' )## in the continuum case (in the first case there's a Kronecker delta and in the second there's a Dirac delta).
Likes bhobba
Actually defining path integrals properly is rather difficult and touches on some rather interesting, but advanced areas of applied math such as White Noise Theory:
http://www.kurims.kyoto-u.ac.jp/~kyodo/kokyuroku/contents/pdf/1797-03.pdf
At the level below that ie at the level of the typical undergrad treat it like you would the Dirac Delta function - a normal function that for all practical purposes has that property - simply think of the path integral like a post I did about it ages ago:
You start out with <x'|x> then you insert a ton of ∫|xi><xi|dxi = 1 in the middle to get ∫...∫<x|x1><x1|...|xn><xn|x> dx1...dxn. Now <xi|xi+1> = ci e^iSi so rearranging you get ∫...∫c1...cn e^ i∑Si.
To get the path integral you are supposed to take the limit - but rigorously defining such is rather difficult. So just think of it as something where the difference between the xi is very small - but not actually zero. Sort of like you do in the early stages on calculus with how you view the integral as a sum with the Δx really small.
Thanks
Bill
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
