Is There a Mathematical Link Between These Equations?
  • Thread starter Thread starter cdux
    Arithmetic
The discussion centers on the mathematical relationship between the equations 2ab and 1 - (a^2 + b^2), specifically when a and b sum to 1. It is established that rearranging the equation leads to the identity 1 = (a + b)^2, confirming the observed equality holds true under this condition. The participants note that this property applies when a + b equals either 1 or -1, with the latter being less common. Additionally, it is mentioned that the scenario where (a + b)^2 equals a positive constant is more likely than when it equals a negative constant. The conversation concludes with an acknowledgment of the implications of these mathematical properties.
cdux
I've noticed 2 x 0.2 x 0.8 happens to give the same result with 1 - (0.2^2 + 0.8^2).
Can the latter be rearranged to the first? And if yes, can someone direct me to the name of the branch of math that describes this problem? It definitely reminds me of something from high school I didn't pay attention to..
Mathematics news on Phys.org
Oh wait, I guess for this question to avoid being meaningless 0.2 and 0.8 should get the symbols A and B, otherwise it could just be 'rearranged' to 0.32.
Hrm, I managed to rearrange it to 1-(A+B)^2 = 0. So that might mean it's a property that ONLY applies when A + B = 1, or at least when that '1' being C is A + B. Am I right?
Or wait, also when (A + B)^2 is C, which is rarer.
So rearrange the equation that way...
2ab = 1 - ( a2 + b2 )
Now rearrange to put the constant term on the left and the rest of the terms on the right...
1 = a2 + 2ab + b2
If you manage to get it in this form, the right hand side is recognizable
1 = (a+b)2
So you can conclude that as long as a and b add to 1 then the relationship that you observed will hold good. The actual a and b that you chose are 0.2 and 0.8. Those do add to 1.
EDIT: It appears that we crossed posts. You have already realized this.
Likes 1 person
1 = a2 + 2ab + b2
1 = (a+b)2
Is my additional assessment that also (a+b)2 could be 1 correct? (Or I guess = C if 1 = C there)
so, 2ab=1-a^2-b^2
a^2+b^2+2ab=1
(a+b)^2=1
'Property' applies when a+b=-1 or +1
Not much of a mystery
Mr.E
Actually twice as likely for C positive and impossible for C negative.
[Although it is sloppy to talk about likelihood rigorously without a probability distribution available]
Likes 1 person
True.
I don't get the first part. Why is it more likely? (even if it's loosely described)
edit: Unless you just mean because it excludes the negatives.
Yes, that's all I was getting at. That there are two values of a+b for which for (a+b)2=c
as long as c is strictly positive.
