What do t, p, r mean in Studies?
  • Thread starter Thread starter Flying Penguin
In studies, "t" refers to a test statistic from the t-distribution, which is used in hypothesis testing, while "p" denotes the p-value, indicating the probability that results occurred by chance under the null hypothesis. The "r" represents the sample correlation coefficient, measuring the strength and direction of a linear relationship between two variables, ranging from -1 to 1. Beta symbols indicate regression coefficients in statistical models. The discussion highlights the importance of understanding these statistical terms for interpreting research findings, particularly in psychological studies. Overall, these notations are essential for analyzing data and drawing conclusions in scientific research.
Flying Penguin
In studies, they always refer to certain variable values or something. Like: one-sample t (64) = 7.02, p < .0001. This overestimation occurred even though self-ratings of ability were significantly correlated with our measure of actual ability, r (63) = .39, p < .001 or This was true for the first set of self-appraisals, &Beta s(67) = - .40 to - .49, p s < .001, as well as the second, &Beta s(67) = - .41 to - .50, p s < .001
what are t, p, r etc. ? :confused:
I know I should know this but it's been a looooooong time.
Poop. Those "&Beta"s are meant to be Beta symbols.
Mathematics news on Phys.org
Can you provide a link to the entire source material? It is possible that this is some kind of notation common in the field from which this quote came from.
- Warren
This sounds like an abstract from a psychological studies. I am not sure about the symbols. But in general in statistics, "r" refers to the "sample correlation coefficient" between two variables. "r" lies in the range from -1 to 1. A positive (negative) value indicates a positive (negative) *linear* correlation between the two variables. Since in studies we can only take a finite number of samples, we can only hope to estimate r using the data that are available to us. In this process of estimation there is likely to be "errors".
As to "p", it is called the "p value" and 1-p is called the "confidence level". It is tied with something called "hypothesis testing" in statistics. I do not see any hypothesis in the piece of writing so I cannot explain it.
As to the one sample t and beta, I think they are some "test statistics" for some hypothesises. But without knowing the hypothesises I cannot say any further.
"t(n)" most likely refers to t-distribution of n degrees of freedom and "p" is the probability that the given "t" results could have occurred purely by chance given the "null hypothoses". Note the a "t" distribution is a common probability density function that is quite similar to the Normal distribution. The quoted example is a little unusual as "t" distributions with degrees of freedom greater than 30 are rarely used as they are extremely well approximated with the normal distribution.
"r" is a corelation coefficient, and "Beta" is yet another distribution function.
Thanks guys. That was indeed from a psychological study (http://www.apa.org/journals/psp/psp7761121.html - a most interesting read!), but I've seen similar notation in numerous other places. thanks again.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
