Simple Surface Integral - Heat Flow on Surface of Star
3 replies · 2K views
wadawalnut
I have this problem in an online assignment. Someone told me the answer, so I already got it right, but I don't know why my logic leads me to the wrong answer. The problem:
The temperature [itex]u[/itex] of a star of conductivity 1 is defined by [itex]u = \frac{1}{sqrt(x^2+y^2+z^2)}[/itex]. If the star is a sphere of radius 5, find the rate of heat flow outward across the surface of the star.
Surface integral: [itex]\int \int_S f(x,y,z) * dS[/itex]
Surface area of sphere = [itex]4\pi r^2[/itex]
The correct answer is [itex]4\pi[/itex]
I tried this two ways and got the same answer both ways, unfortunately this answer isn't correct.
First method was flat out doing the integral. Firstly, it is clear that [itex]u = \frac{1}{| \vec{r} |}[/itex]. However, the radius on the surface of the sphere is always 5, so [itex]u = \frac{1}{5}[/itex]. If we use the parametrization [tex]\vec{r} = (\rho \cos(\theta)\sin(\phi), \rho \sin(\theta) \sin(\phi), \rho \cos(\phi))[/tex] And dS is [itex]\rho^2 \sin(\phi) d\phi d\theta[/itex]. Once again, [itex]\rho = 5[/itex] for every point on the surface of the star. Now we can fill out the surface integral:
[tex]\int_0^{\pi} \int_0^{2\pi} \frac{1}{5} * 25\sin(\phi)d\theta d\phi \\<br /> = 5 \int_0^{\pi} \int_0^{2\pi} \sin(\phi) d\theta d\phi \\<br /> = 10\pi \int_0^{\pi} \sin(\phi) d\phi \\<br /> = 10\pi (-\cos(\phi))|_0^{\pi} = 20\pi[/tex]
I knew that wasn't correct, so I thought of an alternative: At each point on the surface, the value of the function is just [itex]\frac{1}{r} = \frac{1}{5}[/itex]. So shouldn't the surface integral evaluate to the surface area of the sphere multiplied by the function u, and thus [itex]\frac{4\pi 5^2}{5} = 20\pi[/itex]?
It seems like the value doesn't depend on the radius.
Can someone explain this to me?
Your ##u = u(x,y,z)## is the temperature at the point ##(x,y,z)## in the star. How is the rate of heat flow across the star's surface related to the function ##u##? In other words, how is your function ##f(x,y,z)## obtained from the function ##u(x,y,z)##?
In general:
$$\iint_S f(x, y, z) \space dS = \iint_D f(\vec r(u, v)) |\vec r_u \times \vec r_v| \space dA$$
For this particular problem we can adapt the notation:
$$\iint_S u(x, y, z) \space dS = \iint_D u(\vec r(\theta, \phi)) |\vec r_{\theta} \times \vec r_{\phi}| \space dA$$
You need to find a suitable ##\vec r(\theta, \phi)##, and project the sphere onto the x-y plane to obtain the region ##D##. Take ##\rho = 5## for the parameterization.
Zondrina said:
In general:
Do we know that ##f = u##? I asked the OP that, but have received no response.
