Simplify \sum_{i=0}^{n}\binom{n}{i}2^{n-i} to 3^n
  • Thread starter Thread starter noblerare
The discussion focuses on simplifying the expression \sum_{i=0}^{n}\binom{n}{i}2^{n-i} to demonstrate that it equals 3^n. The original equation was rewritten, but the poster struggled with the next steps due to the changing combinatorial and powered terms. A hint was provided, referencing the binomial expansion of (2 + x)^n. The poster realized the solution after considering this hint. The problem was successfully resolved with this insight.
noblerare
This is actually part of a larger problem that asks us to prove that the number of ways of counting something is equal to 3^n. I have worked it out and the equation I get is:
\binom{n}{0}2^n + \binom{n}{1}2^{n-1}+\ldots+\binom{n}{n}2^{n-n}
I am wondering how I should simplify this to make it equal to 3^n
2. The attempt at a solution
I rewrote the above equation into:
\displaystyle\sum_{i=0}^{n}\binom{n}{i}2^{n-i}
But then I didn't know how to proceed from here since both the combinatorial choosing term and the powered terms are changing. I also tried factoring out 2^n but that didn't do anything.
Can anyone help me?
Thanks.
Hi noblerare! :smile:
Hint: what's (2 + x)n ? :wink:
Ohhhh, wow. Okay thanks, tiny-tim! Problem solved.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
