33 replies · 24K views · last reply
pongo38
- 739
- 27
rad10k said:Pongo38 : Well for instance the formula in post 20 : w = 4M/e. That was originally in my textbook as a formula for maximum bending moment : M = we/4 for a simply supported beam with point load in the middle but had been swapped around to solve to be used to solve W. I don't understand why the 4 was moved to be multiplied by M and then divided by e ?? Hope this ellaborates more on what I means
w = 4M/e is an equation where the left hand side is equal to the right hand side. If you divide both sides of the equation by 4, then the equality should hold. So, w/4 = M/e because 4/4 is the same as 1.
Then if you multiply both sides of the equation by e, then the equality still holds. So, we/4 = M.
Does that cover the point you are making?
Incidentally it is conventional to distinguish between upper case W and lower case w. So you should be careful to use the same symbol throughout.
rad10k
- 60
thanks pongo38 that helps.
nvn : I spoke to my tutor and explained that I was getting the same answer using the formula in post 23. Apparently I am solving ObZ/k = M incorrectly and should be using EL = M
then using the formula in post 23.
E = 204 000
E = 204 000
john thompson
- 1
hi i am have the same problems with this quetion you mentioned that your tutor said use EL= M i asume that E is modules of elastcity in N/mm2 and i assume L is length of beam in mms and you also say that the formula is post 23 but i cannot work out which formula you used any help and i would be very greatfull
Engineering
Deflection and Slope of a Simply Supported Beam
- Tomarama24
- · Replies 8 ·
- Engineering and Comp Sci Homework Help
- Replies
- 8
- tzx9633
- · Replies 2 ·
- Replies
- 2
- benwb93
- · Replies 4 ·
- Replies
- 4
- Al_Pa_Cone
- · Replies 46 ·
- Replies
- 46
- Buzz_Lightyear
- · Replies 16 ·
- Replies
- 16
- FEAnalyst
- · Replies 6 ·
- Mechanical Engineering
- Replies
- 6
- andrewh21
- · Replies 3 ·
- Replies
- 3
- FEAnalyst
- · Replies 13 ·
- Replies
- 13
- Michael V
- · Replies 8 ·
- Replies
- 8
- raymanmusic
- · Replies 5 ·
- Replies
- 5
